F201
#286
Steve- Good racing today...... it was nice seeing two full heats of F1 cars out there today.........
#287
Thanks Rto, I agree, it's great seeing two full grid of F1s
Steve Wang
Speed Tech R/C
F1RL
www.speedtechrc.com
www.f1rl.com
Steve Wang
Speed Tech R/C
F1RL
www.speedtechrc.com
www.f1rl.com
#288
F1 Guys,
We just finish our first round in our six round points series. I updated the website with current standings, stats, and photos through out the website. Check it out guys
Steve Wang
F1RL Commissioner,
www.f1rl.com
Steve Wang
F1RL Commissioner,
www.f1rl.com
#289
F1RL Members,
If you don't already know, we are currently voting for a different spec power plant for the second round. Those of you in the series, please visit the website immediately for more information.
Other racers on this thread, you guys are more than welcome to give m your input and suggestion on the rule change
Steve Wang
F1RL
www.f1rl.com
Steve Wang
F1RL
www.f1rl.com
#290
Kit motor
Our f1 class is going to be the kit motors. We wanted it to be cheap for people to get started in and with as slow as they are, crashes are a lot less likely.
I have a question about the high speed gear set, is it too high a gear for the kit motor? Is it meant for 27turn motors?
#291
Claydoh,
Thanks for visiting our website, and yes, i agree with you on the mabuchi motor. It will be easier for people to join in and the speed won't be as intimidating. For the fast guys, this should not be a problem either, if you're fast, you are fast with a mabuchi, stock, or 19T.
the high speed gear set gives you a ratio of 5.88:1, which is fine for mabuchi. The kit mabuchi is no longer the silver, but a slightly faster sport-tuned one. The fun part about mabuchi is you can have one guy gear high and one guy gear low, and one would be faster on the straight and the other will catch him in the infield
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
#293
OSherman,
Actually, we are leaving the gear ratio rule alone, and I'm thinking about stretching the main time to 10 minutes. This way we have a loose control on the gearing, but still allow flexibility in there for racers to gear their cars differently.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
www.f1rl.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
www.f1rl.com
#294
Hi Guys,
We just received more F201 hop-ups from Tamiya. Website is current, check it out when you guys get a chance. Also, F1RL Racers, second round is coming up Jan. 11th
Steve Wang
Speed Tech R/C
F1RL (Formula 1 Racing League)
www.speedtechrc.com
www.f1rl.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
www.f1rl.com
#296
Originally posted by rc-zombies
I was looking at David Jun's set-up on the Tamiya website..
what is 3000 wt oil equivalent to? thanks in advance.
Steve..
Got the Cross chassis.. thanks!!!
Can't wait to run ut.
Steve..
#298
au contraire! Jun is actually using silicon diff oil on that setup. I'm not sure what brand, though. Most guys in the Bay Area are using Mugen 3000 weight oil. The oils that are rated as #300, #600, etc. more or less translate to Trinity weights if you take the last zero off, so #300 oil is about the same viscosity as 30 weight oil.
#299
Is 3000 not 300wt?????
