Rs Pro
Rs Pro
Haloooo.....
I'm using a T4, with Rs Pro n Tekin Gen 2 13.5R, 4 Pks, fdr 5,2.
Something weird happened this noon.
Why my baterry is only ok just for 4 or 5 minutes only, even I used my race battery, just the same.
After 4 or 5 minutes, the car is going slowly. I'm already using this esc just for about 2 or 3 months, for the first time and until last week everything goes well.
Do anybody have had the same experience with me?
Pls share.
Thks
Pls share.
Thks
What battery is it? What are your esc settings?
Pls help......
1. Set the throttle endpoint to 90% on your radio.
2. Calibrate the speed control whilst at 90%.
3. Now set the throttle end point on your radio to 100%
What can happen sometimes is the full throttle signal can "drift".
Turbo will only activate when the speed control see exactly full throttle. This signal drift can cause the speed control not to engage Turbo.
I had similar problems to yourself and this trick fixed it completely.
Good luck
Good luck
