Schumacher Mi5
#2281
Trader Rating: 102 (100%+)
spare up for grabs
Just in case anyone is interested...
I have a nip upgrade chassis for the MI5.
I think the part number is u4398
http://www.rctech.net/forum/r-c-item...acher-mi5.html
#2283
THAT is a really small spur gear!!!
#2284
Wow that looks funny!!
#2287
Here is my 44t just about keeps the belt on
on another note anyone having trouble with the car going light on the back end in high speed banked sweepers and turning around
#2289
waiting for my mount to arrive and do you think a 17/18 pinion will fit ok as well as we also run 21.5 turbo so looking at around 4.5 fdr for that and around 3 or lower for blinky 21.5
#2290
Thanks I will try that will also try and get you a setup I was using also
#2291
I run 17.5t blinky and a 44 with a 26 pinion gives you 3.05 fdr I will have to church how big you can go maybe 27-28 pinion also can try a 17 on it see if that also fit
#2292
Has anyone cut the wishbones yet on the Evo ? is it worth doing ?
#2294
will try the 1mm under the rear wishbone balls but if there is any thing else u see that culd be wrong
i was told to try taking the 1 mm from the rear inner upper arm ball studs whats ur view on this
#2295
