Speed Passion  F1 car - The SP1 >
Like Tree4Likes
Old 09-12-2013, 08:04 AM
  #541
Rick Vessell's Avatar
Originally Posted by Solara
When Socko asked.....I answer WHEN and WHERE.....
Now and you have my address.
Rick Vessell is offline
Old 09-12-2013, 08:28 AM
  #542
Trader Rating: 17 (100%+)
Originally Posted by Ph3nyx
Ok ! thank you for this clarification, that is smart ! hope we'll test it soon for rcf1.fr
so we saw the audi e-tron body, what are the others ?
Please don't name names, that body is NOT the Audi, we are only using the Audi paint scheme for that. The same body also been used for RED BULLS and FERRARI, and they all works well......all I can tell you is we have several others current up to date bodies in production
Solara is offline
Old 09-12-2013, 08:34 AM
  #543
Originally Posted by InspGadgt
The lower front pivots on the arms on mine are starting to develop a bit of slop between the pivot and the king pin...the hole the king pin goes through is getting enlarged. Will there be a metal option soon for the pivot balls? Has anyone found another brand one that might fit?
We WILL have the metal one (spring steel type) coming out...
Solara is offline
Old 09-12-2013, 11:34 AM
  #544
metalnut's Avatar
Trader Rating: 36 (100%+)
Xenon makes a few different spur gears so make sure you get the right ones. I'd check but the Stormer site is not loading for me right now. Make sure you get the VSS DD spur gears. I run an 88 on mine.
Thanks for that detail, you were right, Stormer had the other kind of Xenon spurs. But, I found the VSS DD spurs at Superior Hobbies: http://www.superiorhobbies.com/store...R+GEAR+64P+88T
The 88 is out of stock so I got the 86 with a few Robinson Racing pinions. I really appreciate the help
metalnut is offline
Old 09-12-2013, 11:39 AM
  #545
Cool...spring steel will hold up well over time. Are there plans for some sort of coating to help prevent them from rusting and keeping them smooth?
InspGadgt is offline
  #546
Pls make them hard anodized teflon coated aluminum.
Sydewynder is offline
Old 09-12-2013, 12:32 PM
  #547
Can you tell when it's available ?
Gurneyflap is offline
Old 09-13-2013, 08:48 PM
  #548
spring71's Avatar
Smile
SP1 kits and parts are available at TQ.
http://www.tqrcracing.com/shop/produ...id=43&s_sort=3
FYI, Thanks.
spring71 is offline
Old 09-16-2013, 05:31 PM
  #549
metalnut's Avatar
Originally Posted by liljohn1064
Built - the ball links need to have a little bit of material removed inside to allow the screw to thread all the way in. Looks like a little bit of flashing from machining left inside.
So, I got my kit today, and sure enough the balls have flashing in them. For the life of me, I can't figure out how to get it out, and I don't have any replacements that would be the right size. This is extremely frustrating and pretty unacceptable if you ask me. How are you guys getting around this problem?
metalnut is offline
Old 09-16-2013, 06:18 PM
  #550
Cadman1981's Avatar
Hey guys, i am not sure if this was already posted
http://rcf1blog.blogspot.ca/2013/07/...sion-sp-1.html
What does moving the links at an angle do to make it "feel more planted"?
Cadman1981 is offline
Old 09-16-2013, 07:28 PM
  #551
My guess would be that it reduces rear steer inherent in any link style pan car suspension.
Old 09-16-2013, 07:32 PM
  #552
metalnut's Avatar
Did you drill the middle holes yourself? My only came with the two holes, no middle one.
metalnut is offline
Old 09-16-2013, 09:06 PM
  #553
Trader Rating: 42 (100%+)
You would have to drill those holes.
That being said I'm running his set up without those drilled holes and on carpet my SP-1 ran great.
Nexus is offline
Old 09-16-2013, 09:07 PM
  #554
metalnut's Avatar
Hrm... ok, I have a front ride height question now. Looking at Solara's 184mm conversion shim picture (http://i146.photobucket.com/albums/r...ps128dd840.jpg), I see 2mm under the suspension plate and 3mm under the arms. Why not 1mm under the suspension plate (kit height) and 4mm under the arms as the manual suggests? I'd like around a 5mm front ride height with Pit rubber tires.
metalnut is offline
Old 09-16-2013, 09:29 PM
  #555
My manual shows 2mm under the arms. I left the shims under the arms the same and raised the plate and servo mount for ride height. That way the steering geometry didn't change.
