Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree1130Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 01-13-2015, 12:13 AM
  #571
Originally Posted by redbarton
Has anyone done an in-depth review on the TT02 type S yet? I've not seen much on the net including Youtube. I guess this version of the TT02 isn't in many people's hands yet outside of Japan. I'm sure something will appear soon, but I'm just not enjoying the wait.
Hint, hint...for thercracer.com
I'm looking for a VTA/USGT budget racer from a major company like Tamiya. I'm not interested in a TC4 (owned 2 already), Sakura (had 2 zeroes already), or Spec-R S2 (worried about parts support, honestly).
I haven't seen much of information about building de Type-S version eather, only 2 movies on Youtube when the car is on a track.
I'm still considering to buy one but my TT-02 is doing very well on the track.
Perhaps i should buy one and sell my TT-02, cause all the needed parts for building a regular TT-02 are included in the kit. Except the drive shafts.
I also have the Spec-R S2 and that car is very good aswell, parts can be found easily at TQracing. So parts for that car shouldn't be a problem.
addicted2blue is offline
Old 01-13-2015, 05:17 AM
  #572
The TT02s is pretty sweet, I'm very busy with real work atm but a review will come soon.. The only thing that bugs me is that there is no droop screw setting, you have to use spacers in the shocks. It's not a big issue and once you get a set-up then its cool its just that I do not like getting my fingers dirty
Qatmix is offline
Old 01-13-2015, 08:41 AM
  #573
@Qatmix,
Always working, you should have some priorities about building tamiya cars (Just kidding)
Tamiya should design a new B8 part that gives the opportunity to use droop screws.
Very easy and could be sold as an option part.
I have been thinking of designing the part for myself and get it 3D printed
Old 01-13-2015, 09:55 AM
  #574
Originally Posted by addicted2blue
@Qatmix,
Yep, I was disappointed that they didnt just do this on the TT02s, I have tried to to a basic mod to the current part but it moved too much so it was not any good.
I need to do the 419 review before the TT02s.. Hopefully I'll get them done soon.
Qatmix is offline
Old 01-13-2015, 10:49 AM
  #575
firefoxussr's Avatar
Excited to join the TT02 crowd. Got a deal on ebay - an unbuilt parts set minus wheels, body, and electronics.
It's perfect for 'fixing' my Nikko Ferrari F430, this purchase solves these issues:
-RWD with open diff (nightmare)
-2S hardcase is rubberbanded in place cuz does not fit 7.2v round tray
-standard servo doesn't fit centered (non-standard on original car)'
The only other thing on my mind was- currently the car uses a stock TA02 Ferrari 360 Modena body, are the body post holes compatible with the TT02?
firefoxussr is offline
Old 01-14-2015, 02:39 AM
  #576
Smile's Avatar
Yes, as far as I know, the Ferrari body's holes would fit, just like any other 190mm Tamiya body out there. The TT02 has reversible rear body posts, which means that even the older bodies would be compatible.
Smile is offline
Old 01-14-2015, 09:41 AM
  #577
Thanks! Also I do like the RWD feel on my cup racer, which I think is cuz they did gear diff in front and ball diff in back. Anyone do ball diff in rear only for a TT 02/01?
Old 01-14-2015, 02:07 PM
  #578
I've mounted 2 ball diffs in my TT-02, the car runs great and has less noise.
Old 01-14-2015, 03:56 PM
  #579
hairless_ape's Avatar
You could easily ad a thin carbon fiber plate to the underside of the chassis, and then use the existing droop screw holes in the 418 arms that are on the S.
hairless_ape is offline
Old 01-14-2015, 04:47 PM
  #580
Djchow85's Avatar
With whatever oil you used did you find a significant handling difference vs gear diffs?
Good to see this thread come to life again - even though I've moved on from on road/tt02.
Djchow85 is offline
Old 01-15-2015, 12:04 AM
  #581
I have been using 100.000, just enough to have the correct feeling.
The gear diff's are not consistent enough, you have to refill the gear diff's very often to get the right feeling and they leak a lot.
Or when you use AW grease the feeling at the start isn't the same as when you ran the car once or twice.
That's what makes the ball diff's a better choice, they are more consistent and moore smooth with less noice.
Currently i'm testing the car with a 17.5T motor and still i'm improving my lap times. Tonight and saterday i will be testing some setup changes.
Old 01-15-2015, 03:36 PM
  #582
redbarton's Avatar
Maybe someone could talk t-bone-racing.net to manufacture something like this for the TT02S? They make bumpers and skid plates for all sorts of R/C's already. Something similar to this would be perfect:
http://t-bone-racing.net/TBR-DS-rear...t-T-p1539.html
Ride height might not be so good afterwards, though.
redbarton is offline
Old 01-17-2015, 06:32 AM
  #583
Theibault's Avatar
Doing a TT-02 Type S build video on my YouTube channel. If you like, be re to subscribe to get a updates for the next part.
http://youtu.be/PVbFUd-DqYg
Theibault is offline
Old 01-17-2015, 04:53 PM
  #584
dude nice vid hope to see the rest of them
TeamThibault is offline
Old 01-17-2015, 06:34 PM
  #585
Theibault's Avatar
Thanks! Love your last name.
