TLR TEN-SCTE 2.0 Kit Thread
#7156
Does anyone know if the motor position on the MIP chassis is in the same position as it is on the 2.0 chassis? side by side with my brothers (I have the MIP and he has the stock 2.0 chassis) it look like the stock position is farther back. The reason I am asking is because we went and got in some good practice time Sat. at Sparks, and we drove each others trucks and although I really liked how I ended up getting mine to handle, it seemed I could hit some of the corners harder with mine than his, but his seemed to jump better and stay a lot flatter. And although we knew the track was not as good as it is on race days, we were seeing times 3-4 seconds off the fast guys who make the A. I know a lot of it is just our driving as we don't get a chance to do it as often as we would like.
#7157
#7158
Is there anything I can do to help it jump better at least o help keep it flat?
#7159
Tech Prophet
Typically all it takes is staying on throttle a touch longer.
Also make sure your suspension is free. Shocks wiggle on bushings, swaybar is free to move side to side sligthly type of things.
#7160
Like I mentioned before, my brother has the stock chassis and jumps nice and flat, I have the MIP chassis and it is not bad nose diving but no where near as flat as his. I went through my truck before we went to practice this past sat. and everything in the suspension is straight and free, there was no binding at all, before practice I did find that the set screws on the sway bars were way tight but I loosened them up before we ever started to practice, I do need to take the shocks apart and check and see what pistons are in them because other than changing the oil in them when I got it I never looked. what is a good piston and oil for this I have 32.5 in them now which prolly is not correct. and I got the ride height down to 26.
#7161
Tech Prophet
some great setups at www.casper-rc.com for this truck. I will be posting the lastest dunford setup most likely tonight but the shocks are the same as the most recent setup I have up there.
Weight balance can obviosly affect jumping as well as shock package and other things like antisquat and such. Just saying this other truck jumps better as it has a MIP chassis and the setups may be very different (I don't know you tell me) is hard to understand why it might happen. If you can control the car in the air and it gets around the corners better it should be faster. Tweaking a setup to get "flatter flight" easier at the expense of corner speed is never a compromise I would make. some seem to have more issues with jumping the trucks then others and some has to do with the track some has to do with how the driver jumps the car. In this case you are the driver of both so it leads to setup or possibly the chassis configuration without knowing more about the setups it is hard to make that assesment.
Is it hard to jump or just "not as flat". I ask again related to not redoing your whole setup if you feel it is working well just to get to to jump a little better.
Nose down landings at least getting the truck parallel to the landing ramp is the best way to get around the track. Most of the time you want to down side the jump to get back on power is the fastest way around a track.
#7162
it is not hard to jump at all, and as I did drive both trucks, and he mine it may be I'm just more use to mine and like it better than his other than his with stock chassis and Mine MIP I could just jump his flatter and I do know a lot of it is our driving. Im not complaining at all about the truck as I do really like it and do need more track time to learn.
#7166
Thanks for the feed back Casper, I'm just trying to learn all I can about this truck to make it and myself better.
