"Floating Servo" holder - why would I want it? >
Old 02-09-2013, 05:29 AM
  #31
Matthijs's Avatar
Originally Posted by EDWARD2003
Can you not get the same "floating effect" by double siding the servo to the chassis and mount the servo to the inside servo mount?
Originally Posted by sosidge
Absolutely. It's cheaper, lighter and simpler.
compared both solutions, servoholder gives more clearance and visible more flex under the servo (on the bench ;-) )
Matthijs is offline
Old 02-09-2013, 04:23 PM
  #32
YoDog's Avatar
Trader Rating: 28 (100%+)
Not nearly as SEXY!
Servo tape, that is...
YoDog is offline
Old 05-11-2013, 02:50 AM
  #33
Typeone's Avatar
Trader Rating: 50 (100%+)
Hey Yodog I also stay in fresno, ca I'm looking at your servo kit for the tc6 I have the tc6.1 worlds kit would it work if so can you give me a call at (559)307-9279. Names Tim also how much is your kit. Thanks
Typeone is offline
Old 05-12-2013, 09:46 AM
  #34
YoDog's Avatar
The servo mount is a direct fit for all TC6.x chassis.
I am currently out of the latest version but I can sell you the model without the battery stay and then update you with the new upper plate when I have more made. (ran out of 2.5mm carbon plate)
Price is $20 each.
[email protected]
I race fairly regularly at HobbyTown USA, We can meet up there.
YoDog is offline
Old 05-12-2013, 12:54 PM
  #35
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by YZFAndy
The idea is aimed more at allowing the servo and steering pulleys/rack to move about at the same rate relative to each other and to stop unwanted steering action as the chassis flex's.
I'm with you in theory but in reality can you feel the "unwanted steering action" when driving ? Surely different cars have this effect to different degrees. Not just brand but 1/8th vs 1/12th and so on....
asc6000 is offline
Old 05-20-2013, 09:01 AM
  #36
Timbo99's Avatar
Trader Rating: 14 (94%+)
Talking Hmmmm
Physics 101.
Turn your car over.
Look at how many bolts are in the bottom.
Now look at how they are distributed.
If its not even,flex will be at an altered state.
Bolts down the centre should only be to hold weights for the axis(y axis),to roll on the "x" axis,(roll centre).
The more area you can measure from bulkhead to bulkhead without a screw bolting down something ie servo,battery straps,the more evenly your area of carbon will flex with EFFECT,and alter how the car feels,and will be more precise,from left to right.
They also look cool.
Now turn your car onto its wheels and go play!.......
Tim.
Timbo99 is offline
Old 05-21-2013, 07:36 PM
  #37
JustWill75's Avatar
Wow, I'm not even an engineer and that made total sense to me.......
JustWill75 is offline
Old 05-21-2013, 08:42 PM
  #38
Team Grid RC's Avatar
Floating your Lipo would have a greater impact than the servo.
The servo weighs around 50gr, whereas the Lipo weighs around 300gr. That is a good chunk of the total weight of the car.
Team Grid RC is offline
Old 05-22-2013, 04:59 AM
  #39
Timbo99's Avatar
Thanks!!!
Timbo99 is offline
Old 05-22-2013, 05:05 AM
  #40
Timbo99's Avatar
Default Nonononononono
That's STATIC weight.
The chassis flexes just fine underneath it,and,it's even weight.
When your car if fully loaded,(transponder battery,fans),get four individual small scales,place them under each wheel,and if its even,YOUR CAR will be awesome.
If its REALLY out,
Tim
Timbo99 is offline
Old 05-22-2013, 05:37 AM
  #41
Tim
The chassis flexes when the Lipo is just sitting on it, but not the same flex when you strap it down with tape.
Old 05-22-2013, 06:58 AM
  #42
Radio Active's Avatar
In addition to what everybody else has said a floating servo holder is really great in RC boats.
Radio Active is offline
