DIY {Do It Yourself} TIPS >
Old 04-18-2005, 03:03 PM
Default DIY {Do It Yourself} TIPS
List your do it yourself strategies for anything that has to do with R.C. Even good websites with some tips or instructions.
Pit tips, DIY, Tool Reccomendations, Reviews, just about anything that you can think of that has helped you or made things easier in this great hobby of R.C.
Don't Be Selfish and Grimmy Share your experiences/ideas/thoughts etc.
Help out other newcommers to this great hobby!
drive4fun is offline
Old 04-18-2005, 03:05 PM
I'll start with this one.
http://rcvehicles.about.com/od/rceng...cnitroaf04.htm
Keep all unwanted particles from comming into your car!
Old 04-18-2005, 04:11 PM
WeatherB's Avatar
Good tip. However, how then would you add after run oil without cutting off the zip tie everytime?
I think the key is to make it tight enough to hold the air filter but not too tight so you can remove it at the end of each run and add the oil.
WeatherB is offline
Old 04-18-2005, 04:19 PM
Sow&Steady's Avatar
Share your passion or find some articles, hints and tips, etc at http://3hobby.net
Tips on finding tips there ( ) :-
1- Do a search on a topic
2- In the Main Menu click on "Stories Archives" and look my month, by news title.
3- In the Main Menu click on "Content", for reviews, tips, features etc.
4- In the Main Menu click on "Topics" and find tips that way
5- In the news posts below the Forums Center in the main page, click on the Topic icons (right hand side ones).
6- finally, contribute your own and I'll archive it for others like yourselves to find later on ...
Sow&Steady is offline
Old 04-18-2005, 04:39 PM
teammpp's Avatar
Adding after run oil after every run is overkill. Only need to strip and add it after a full days racing. Only need to replace the zip-tie once that way. The tighter you can get it the better.
teammpp is offline
Old 04-18-2005, 04:42 PM
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
take a body post with a clip @ each end to hold ur spur gears
HotrodHopkins is offline
Old 04-18-2005, 04:45 PM
WeatherB's Avatar
Palmaris,
Sorry that's what I meant... To rephrase, after you're done running for the day
WeatherB is offline
