Hyperform Racing
Old 12-19-2005, 11:11 PM
  #1081
tpczx6's Avatar
Carlos
run about 5000 wt 1/8 diff lube in the tubes
add some shims between the tbar and bottom plate so rear rides lower
also add washers to make font end as wide as you can
you can also nowwer the tplate on the sides a little
do the things that Lino stated also
BUT only do one at a time and see how you like it
for your track ( now that I have been there) I would set car up like this
front
Jaco purple
20 springs with trinty white stuff for lube
5 deg blocks
1 deg - caster
servo flat with rods angle back
run toe in (I see you have yours out that would make car overstear outdoors on that track)try toe in first you will see a big inprovement right away run about 1 deg in and when you check make sure you press on the back part of rims as this will show you how it runs
rear
Jaco pinks
run tires big so you can run ride ht adjusters in the middle of the rear it lowwer the weight of the motor below center
30wt oil in cener with stock spring
5000wt diff in tubes
1mm shim under front of tbar
add 1mm shims between tbar and motor plate
3.5 mm ride hight
batts all the way to back
also what are you running on tires
I would run pargon and rub it into tires as mutch as you can
call me if you need more info
hope this helps
(quote) Plus he only runs on carpet for he most part that I know of.
Carlos
I ran outdoors for about 20years only ran carpet once are twice a year during that time. started to run carpet at mikes when he opened. at the regionals I have not ran outdoors 1/12 for about 10 years just had to dig into the old head to find the things I used to do back then to make car work
Tim
Lino airfare is book for the birds hotel ready and geting parts ready to go see you there.
tpczx6 is offline
Old 12-19-2005, 11:58 PM
  #1082
Hyperform Racing's Avatar
Nice, we have our hotel room also, just need to send in my entry and get a flight. Next stop for the HYperform train though is Novak Race followed by the January Jam at RC Madness. Then we get to start thinking about Snowbirds...
Hyperform Racing is offline
Old 12-20-2005, 06:10 AM
  #1083
theisgroup's Avatar
Originally Posted by tpczx6
Carlos
man, that make you older then dirt.
theisgroup is offline
Old 12-20-2005, 11:29 AM
  #1084
Yeah, we're talking about a guy who was on the AE worlds team in the 80s. Definite old fart...
Old 12-20-2005, 11:33 AM
  #1085
theisgroup's Avatar
hey weren't rc cars on strings back then and the motor was a zipper that you pulled to make the wheels spin?
Old 12-20-2005, 01:10 PM
  #1086
ha, poor Tim...
I got your message btw Tim, sorry I missed your call.
Old 12-20-2005, 02:32 PM
  #1087
tpczx6's Avatar
Ok Yang
cars back then did not even have springs we used washers to adjust them
dont make me get out the old cars and run pass you with one
tpczx6 is offline
Old 12-20-2005, 07:15 PM
  #1088
CarlosG.'s Avatar
Trader Rating: 12 (100%+)
Ok Yang
I would like to see that, Yang being schooled by Tim.
CarlosG. is offline
Old 12-20-2005, 07:16 PM
  #1089
CarlosG.'s Avatar
Oh, I forgot, he schooled the both of us at the regionals.
CarlosG. is offline
Old 12-20-2005, 09:03 PM
  #1090
tpczx6's Avatar
Originally Posted by Hyperform Racing
ha, poor Tim...
thats ok Lino call me anytime phones alway with me
tpczx6 is offline
Old 12-20-2005, 10:42 PM
  #1091
Yeah, I'm the opposite.... Emails please!
Old 12-21-2005, 06:13 AM
  #1092
theisgroup's Avatar
for me, that happens every weekend.
Old 12-21-2005, 06:14 AM
  #1093
theisgroup's Avatar
ha, poor Tim...
you forgot OLD. hehehe
Old 12-21-2005, 09:21 PM
  #1094
CarlosG.'s Avatar
Default Merry Christmas and a Happy New Year!!!!!!!!!!
I just want to wish all of Hyperform Racing a Merry Christmas and a Happy New Year. Also good luck the Snowbirds and the Novak race when you all go.
CarlosG. is offline
Old 12-22-2005, 01:52 AM
  #1095
Thanks Carlos, same to you. You have a Holiday HP package in the mail. Enjoy!
