Kyosho Touring Car
#1231
Originally Posted by sosidge
Unless the carpet is very low grip or very bumpy, run the anti-roll bars. Makes the car a lot smoother and better balanced.
I normally try and get a decent no roll bar setting, then throw the bars on, always seems to make the car nicer on carpet.
#1232
car
Originally Posted by celtic
thanks dude makes sense now ran car on carpet rubber tyres at weekend set up front camber 1.5 toe out 0.5 bulk heads flat on chassis 1mm spacer inner top camber link yellow springs no roll bars. rear camber 1.5 bulk heads flat on chassis 3 toe in 1mm spacer inner upper camber link yellow springs no roll bar car was ok but lots of rolling about what do you suggest
#1233
thanks dude do you use kit bars
#1234
Hi Guys,
Just want to post a quick note we have more TF-5 Stallion parts listed online. Belts and pulleys and some more hop-ups back in stock
Steve Wang
Steve Wang
#1237
Originally Posted by yyhayyim
Sin its debut, what are best results for the Kyosho Stallion? I just cant remember it placing top 5 in past months...
Steve Wang
#1238
#1239
Originally Posted by Customworksking
1st is it low bite or Med to high ? 2nd.what motor ? 3rd.bulk heads are allways flat the only thing u neeed to rais or lower is the suspension blocks via sus spacers ie:1,2,3,4,5.4th oil 5th how long r youe camber links? 6th droop what is it ? let me know and I will tell u what to try...Kevin
#1240
Originally Posted by SpeedTech
I believe Kyosho driver Japan Adachi placed 3rd in the competitive JMRCA Japan Modified National few months ago (for reference, I believe Billy Easton, Marc Rheinard, and Andy Moore were all in the B and C main)
Steve Wang
Steve Wang
#1242
-US Team drivers- Josh Cyrul, Ron Atomic, Jason Swift, not sure about any others..
-It comes with the top bulkhead pieces made out of plastic. You can buy the aluminium parts as hop-ups but the plastic ones will work fine.
#1243
#1244
med to high grip no spacers under suspension blocks down stops 4 all round 19 turn atlas or 19 turn checkpoint money i will messure camber links when i get home tonight thanks dude
try all shocks 1 hole in on tower 50 ae oil all 4 ,try blue ft yellow rear or red
# 2 sus spacers Frt and rear 1.5mm up travle frt 3mm rear 5mm ride height
frt 5.5 rear long camber links frt and rear no spacer under rear inner ball stud 3mm spacer under frt if u need more streering go to 2mm,then1mm then none also try the short camber link hole in the frt 1.5deg camber all 4 run it without sway bars then try Kit bars FT and rear ..try 1.5 to 2 deg rear toe I base mine off A A as the front of the rear blocks so that will = D D out = 1.5 E E out = 2deg the front start with A A in the front and the rear block B B in is 0.5 C C in is 1.0deg if u have a onpower push try #1 spacers under the front blocks only keep the rear @ 2 that is if removing the spacers under the frt camber link does not work so if u remover the #2 spacer's put the camber link back up to 3mm also remove the gray foam off the top of the diaphragm of each shock.... LMK how it works
#1245
To take away roll you need to raise the hidge pins which raises the roll center.
But there is a fine line . If you raise it to much you will traction roll.
I am running 2,2 in front and 3,3 in rear. I run medium bit asphalt.
Hope that helps..
