CEN CTS4
CEN CTS4
Havent had my Cen CTS4 running in a few years and there was some fuel left over. Any idea what i gotta do to get it started when i try, or is the engine screwed?
WD-40
I have used a LITTLE WD-40 on my motor i mean a little WD-40 then put fresh fuel into car then try to start it but try and get all the WD-40 out of motor or it will not start you may also go thru 1 or 2 glow plugs before it will start try it and see.....
Marc Nichols
Birmingham,Alabama
Marc Nichols
Birmingham,Alabama
When you mean "little" you mean?
Also after i put the WD-40 into the motor, try and start it with just the wd or add the fuel and try to start?
Sorry could you explain alittle more?
just a few drops in the header opening or were the glow plug goes then move the fly wheel by hand then clean it out you should be good to go ya clean the WD-40 OUT first then add fuel then try and start it
