Spec-R R1
#1757
If im using a 6.5t or 5.5t motor would it be better for me to go with the 60a or 120a esc? Thanks
#1758
Continuing on with my build. It's almost done.
A couple of issues with the kit, however. It was missing one flanged bearing. One of the four that are in the steering rack. Whatever... I'll source one to fit in there.
I then got to the servo to steering rack rod. The turnbuckle thread on one side isn't to tolerance. It's too small. Just slides in and out of a ball end cap. Also one of the ball end caps is too big for a ball... that's ok, I bought some Tamiya ones I'll use eventually.
All a little unfortunate. I don't mind too much, it's a $100 kit.
Is it worth contacting Spec-R directly or should I just simply go source my own gear.
I might just buy some good turnbuckles. Anyone recommend stuff that isn't overly expensive?
#1759
Quitcherbitchin! My steering turnbuckle wasn't even threaded on one end!
#1760
#1761
#1762
Thinking of picking up an S1 to run in our local VTA. But, I'll probably get the R1 in case I want to switch to TC. How have they been in the VTA class?
The S1 kit is very temping tho....I can get a total VTA setup (with spares) for about what an xray or serpent KIT costs!
#1763
#1764
#1765
got the new 2.25 option chassi today, compeletely different carbon than std chassi, more flex, and more "soft" flex
will order the new topdeck too now, looking forward to try the car on carpet again now with the new parts
chassi is 85mm wide, same as my dremeled std chassi
regarding parts, if you dont have a lhs that sells spec r parts then egr mart or spec r`s own homepage is the best thing, really fast shipping and service, i order all my spec r stuff from them
#1767
Keep in mind, Bappe is in Sweden, so shipping from Hong Kong or the U.S. is six of one, half dozen of the other.
For U.S. addresses, TQ RC is the way to go. I don't know them. I have no ties to them. But I've used them a dozen times and they've yet to screw me over.
I got a broken driveshaft from them that was broken in the package. I e-mailed them with a picture. They refunded my money. I didn't even send anything back. Seem like good people.
#1769
Went ahead and got a used S1, with a few spares, to race in our local VTA....
Gotta wait for it to get here next week to see just what shape it's in. But, it should be good to go from the pics. Motor, esc and tires are on the way. TQ RC shopping cart is full of spares and a body...finish up that order after I get the chassis.
Looking forward to on-roading again!
#1770
Remember the Saft DOES NOT spin like most touring cars, only the spur gear spins on the bearing you put inside it, the shaft moving back and forth means nothing and especially with th S1 shimming it can force the plastic bulkheads in or out allowing some tweak in the car.
I have tons of movement in my shaft with the optional POM inserts and it is no problem and super fast in VTA
