Mugen MTX-4
#1936
Is this right?
pulleys are
oneway 28, mid 18, side 24, side rear 18, break 19, rear diff 41.
When I put the 24 upfront on the side and the 18 in the rear on the side, the belt is way to loose. When I put the 24 up front and the 23 on the rear, it seems tight. but OK. Am I doing something wrong.
pulleys are
#1940
[QUOTE=Seisick]
Problem with reversing the rear body posts, is I am concerned about the rear camber link hitting the body post. As I had said, if you mount the body properly which requires trimming the foam bumper, you don't need to do anything with the rear body posts.
Originally Posted by Scott Fisher
I have seen many people complaining about using a Mazda body on the new car. I spoke to Mugen about this problem, giving them some suggestions.
reversing the rear body posts is still needed with this suggestion?
#1942
Thanks. Now everything is rolling smooth. Some how, I used the side-belt that was not to be used.
#1944
Originally Posted by GrandeGixxer
You can dremel the posts, but doing it the right way(cutting the bumper) you can avoid this. Also remember that moving the body that far forward, the car is going to handle a lot different than if it is back where it is supposed to be.
You are not mounting the body "forward". You are centering it. By doing it the way I am talking about, you are centering the wheels right in the wheel wells.
By doing it your way, the wheels are partially behind the wheel wells.
#1945
please post some pics, scott. thanks a bunch!
#1946
#1947
isn't that a stratus2 body? i have a stratus3 body and it's no problem. i posted a pic of it a few pages back (not a good paint job). i've heard people say something when using the mazda6 body, and that's the reason why i asked scott for a picture so it's clear how it works for those who plans to use the mazda6.
really cool paint job by the way (i signed up to your forum so i can see the blown up pic!).
#1949
dun measure d body to be cut wit foam bumper asmbly,take it out,measure and cut body,mount it on d car nicely,lasthg should do is to put d foam and start trimmin to suite d fron body portion
i dun hv any prob wit mazda 6 and i m stil stickin to it,great structure..
