Like Tree7Likes
Hot Bodies TCXX
Old 05-30-2013, 06:37 PM
  #1126
theclutch's Avatar
Originally Posted by Fred Hubbard
As they say everyone is entitled to their own opinion but when you start grouping everyone into the same catergory without any qualifiable evidence to support such a generalization then there's an issue. ...
You must admit... You're probably in the 1% tile of RC racers! Most of us in the 99% could only hope to be able to setup and run cars like you. I've always been in awe watching racers at your level run cars. So for the rest of us 99%...
And just to qualify my driving skills, I never hit boards during a 4 or 5 minute race unless someone taps me into them. But still "pros" like you are in a completely different ballpark and I always watch in amazement as I can only wonder about the skills and concentration you guys have following other cars so close and getting super close to corners without hitting them!
theclutch is offline
  #1127
Fred Hubbard's Avatar
Originally Posted by trx450racer174
Well as it sits I had to buy Tamiya pistons since I could not find any HB ones and I don't have a CC to use at Stormer since they don't accept PP. O well I hope HB parts support picks up soon.
Thanks for the tips guys.
It will, I know it's hard to see but there is a light at the end of the tunnel. Thanks for being patient with us.
Fred Hubbard is offline
Old 05-30-2013, 08:42 PM
  #1128
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
If it's any consolation, I still prefer Tamiya 3 hole and the HB black machined 3 hole pistons on carpet. My last time out, I went away from the kit pistons and it mellowed the car out a lot.
Hiro recommended it since the smaller diameter pistons create less "pack" in the shock (less aggressive high speed damping). It generally makes the car less grabby and have a little bit less overall bite.
-Korey
Korey Harbke is offline
Old 05-31-2013, 04:13 AM
  #1129
-Korey
Hi, Which Tamiya pistons do you use ?? Part number ?
Also which O rings do you use in the shocks
FLAT OUT is offline
Old 05-31-2013, 07:01 AM
  #1130
jag88's Avatar
What do you guys think of the 6 hole pistons ? I see that Hara and Moore used them in the last WC race. Obviously track conditions dictate there use. What did you guys find ?
Thanks.
jag88 is offline
Old 05-31-2013, 07:30 AM
  #1131
trx450racer174's Avatar
I bought Tamiya p/n 53573 3 hole pistons they fit the 417 and alot of other Tamiya onroad vehicles.
They also have a 6 hole blank if you can find them p/n 42165.
trx450racer174 is offline
Old 05-31-2013, 09:10 AM
  #1132
AGNO's Avatar
Thanks.
Work very well, I use 6 x 1.1 with oil 700/800, they work fine on asphalt in all grip conditions, do not use vent hole.
The diameter of these pistons is very accurate, check the smoothness in the body of the shock absorber, otherwise use a bit of sandpaper.
The increased accuracy of these pistons (even the new 3 x1, 1 TCXX) also offer a better guidance of the shock absorber rod, works as straight, aligned.
AGNO is offline
Old 05-31-2013, 09:48 AM
  #1133
-Korey
On a high grip asphault track what wt fluid would you start with??
I also might drill a 6 hole set to try as well.
Old 05-31-2013, 11:41 AM
  #1134
STLNLST's Avatar
Trader Rating: 32 (100%+)
Thanks.
Ran then at the Reedy race with 90wt Losi oil with silver springs front and rear. Felt better than the 3 hole pistons and 35wt front and 30wt rear.
STLNLST is offline
Old 05-31-2013, 01:57 PM
  #1135
dizzy1's Avatar
Trader Rating: 29 (100%+)
Clint, how did the 6 holes feel compared to 3 holes? I should have tried that at Reedy. I was trying to hold off those Awesomatix and ARC cars in the A main. Could have used an extra .1
dizzy1 is offline
Old 05-31-2013, 03:57 PM
  #1136
Suspended
More like 2 tenths..lol
i am cornholio is offline
Old 05-31-2013, 10:51 PM
  #1137
With the Tamiya or black HB 3 hole pistons, I used losi 40wt typicially. If you need to smooth out the car, and keep the tires cooler, Losi 45wt is good. Smaller technical tracks, Losi 35 or 37.5 is ideal.
I would also not recommend "making" 6 hole pistons. As some others have said, the fit of the outer diameter of the piston is really important to how the 6 hole pistons work. I truly don't think they work the same at all. I drill some of my own and they were really lame on the track haha.
-Korey
Old 06-01-2013, 08:52 AM
  #1138
jag88's Avatar
I found some shock shafts in my parts box which I believe are the ver. 2 shafts. They have an extra groove for the snap ring that holds the piston in a lower position. I don't see any mention of these on any of the setup sheets. My guess is that the lower piston gives more pack and would be used in a low bite condition (?). Does anybody have any experience with these ?
Thanks.
jag88 is offline
Old 06-01-2013, 10:52 AM
  #1139
STLNLST's Avatar
It was a night and day difference. More over all grip and better corner speed. Felt more connected to the track and this may have possibly given you a fighting chance in the A.
STLNLST is offline
Old 06-01-2013, 11:16 AM
  #1140
-Korey
Korey, What wt oil would you recommend for a tight low grip parking lot track using the 6 hole HB pistons?
HD Racer is offline
