Hot Bodies TCXX
#1276
#1277
Soon I will test with raised top deck, as the Andy's car, I'm working on retain plates for the central axis
#1278
My TCX top deck prototype has improved the overall flex, the reactions of car are slightly less quickly, but driving is more constant and consistent, the tests are made with 13.5 blinky.
#1279
On my conversion I found the over all flex to be possibly too much. It had a big push on entry and a snap over steer on exit. The over steer might be due to running a boosted 4.5 on asphalt (it's tough too apply the power smoothly) but stiffening up the rear seemed to help with the over steer which made me think that the chassis might be too soft and winding up on power (corner exit) and then releasing causing the rear to break loose. When they treated the track the car obviously got better. It's really very frustrating as there are too many variables the worst of which is the condition of the tires ...
#1280
#1281
imo I think this is a modified TCX but regardless it's still cool ...
http://www.petitrc.com/reglages/hotb...hen2013061315/
#1282
#1283
#1284
cool !
I read in this thread that HB will offer an update kit. Do you know if that's still going to happen and if so when ?
Thanks.
#1286
On the top deck mod, what is the post from that is used in front of the motor?
#1287
I've been a fan for years but can honestly say where HB is with the TCXX it's brilliant! The TCXX is so tunable and easy to tune my lap times this year are improving leaps and bounds.
Well done HB!
#1288
Hi All I was practicing this afternoon at my local track with the tcxx and I broke the two rear dog bones in the out drive cups in 2 separate runs 1 after the other, I race mod could this be the reason.
#1289
For more durability Im sure you can run the 2mm pin aluminum dog bones, pro 4 steel dogbones, or any 44mm HB dogbones with the appropriate diff blades for the outdrives.
#1290
Does anyone have a starting setup for the upcoming IIC. It will be my first time attending and racing in the 17.5 TC class. Also, I have no experience on carpet as I race mosty on juiced asphalt. So looking for a setup I could easilly transition to for the rug
