YOKOMO Touring Car BD-7
#5506
Those of you with a Hudy setup bench... can you please drop your car on the setup station and check whether you have symmetrical rear toe? Mine sure isn't... I've tried wiggling all the three a-arm blocks, as well as replacing the RR block by a 2.5deg one, my right wheel is still 1deg off...
Look for dot below ball stud
Align both dots both to front
#5507
#5509
Indeed not very clear, on my car by great coincidence both dots face towards the front.
Glad i read this before I had to change one!
#5511
so do dots go to front or rear.my dots on rear and have 3degree toe
#5514
#5515
thanks.
will chan mine round and se if the toe is different
#5516
#5517
Was anyone able to measure difference between toe if dots are facing front or rear?
#5519
Interesting - thanks for sharing!!!
I didn't notice it either at assembly time! What puzzles me is how it can be asymetric... with the stock hub set from the kit. It'd mean Yokomo gives you a 2L or 2R combo, or that the chassis is asymetric by design and the hubs carry asymetric outboard toe to correct this... I will check my car tonight!
Very weird no matter what
cheers
Paul
cheers
Paul
