3 Racing Sakura D3 CS Drift
#1651
Got some practice time today at drift track....getting better with the blind spots. Mounted some new T-Drifts on the stock D3 rims which are off set. Put those ob the rear coupled with +3mm off set fronts and she wou like d understeer needing more power to continue into the drift. Needless to say...would need to tweak it so I can drive it the way I like...or maybe switch them around.
#1653
#1654
Sakura
Can anyone help me with my sakura d3 I just got the heatsink motor mount and I can't. Figure out how to mount cables to make it run:tire
#1655
run the wires through the shock tower with the motor wires then plug into the RX on channel 3 or batt if using an ESC with a bec
#1656
Hello mine come with this small Connections I've never seen before
#1658
it's called a mini JST and they can plug into the RX as the receiver has connections, signal positive negative just make sure the black wire is on the outside and the red is on the centre it should say on the RX which is positive and negative but the negative is usually next to the edge
#1659
Thank you that work I didn't Realise that would work
#1660
Yeah it dose look odd if you have any tips to help me set it up would be very helpful
#1661
get the alloy rear pulley mount, try and find some alloy pulleys, get some good tires try raikou's.
#1662
Thank you I will try that where can I get the Tyres from
#1663
Can anyone help I need a new body and I don't know what one to get it's
BMW or Dodge Or Nissan 350z
#1665
I know I have a BMW for my Other drift car and it dose not fit
You have to bring it Forward quite a lot
I like japspeed car but it's hard to do it
