Yokomo MR4TC-BD
#5251
Thanks guys !!! i have already contact them and tehy have what they want in very good prices!!! So i found what i was asking for thanks!!! But i also think for a narrower chassis!! Right speedy???
#5252
YGPM
#5254
Has anyone been able to fit the SDW front arms on the BD. I believe this setup will give the BD better steering. Please let me know.
Also, has anyone seen Billy Easton's car from the Reedy race. I was interested to know what the setup was or if he had any changes to the car.
#5255
Hi,
yes, I fitted them and tested it on carpet. Unfortunately I broke one and stopped testing. I thought that steering was a lot more agressive and the car felt better.
Cheers
Chris
Cheers
Chris
#5256
Can you tell me how you did that because I believe the rear block(front end) will hit the belt. I am very interested.
#5257
CML Distribution in the UK have a 'Grainger Edition' BD kit that comes with the SDW front arms standard - its a well known trick and works well from the reports i've heard
The arms should just slide on in place of the BD arms, using the BD blocks.
#5258
Hi,
I still used the same suspension blocks as with the standard A-Arms but dremeled away some material at the inside of the SDW A-Arm.
Cheers
Chris
Cheers
Chris
#5259
He had new alum shock tower mounts that had four different positions to mount the inner camber link - very nice. Then there were some new hinge pin mounts that also looked nice. Not to mention the other refinements.
#5260
Originally Posted by speedy-932
Hi,
Cheers
Chris
Cheers
Chris
Did you do anything the get the front track(like wheel spacers) width back to normal or did you just leave it along so the front track was narrower?
#5261
Hi,
I tried both. But especially on carpet I liked the narrower front more because I got more steering.
Cheers
Chris
Cheers
Chris
#5262
Guys i need to make a question !!
Masami edition and BD have any difference in drivetrain???
i notice that the pulleys are different !!! Why is this??
any other differences??
Thanks!!
Thanks!!
#5263
hi does anyone no the spring rates for the new yokomo springs??
thanks mark...
thanks mark...
#5264
Hi,
@Zacharopoulos: Where do you see different pulleys?
@mwoods: I think they are the same spring rate as the old Yokomo ones. Just longer.
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Cheers
Chris
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Cheers
Chris
#5265
Hi,
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Cheers
Chris
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Cheers
Chris
