Yokomo MR4TC-BD
#2461
Originally Posted by Matt Howard
They make the handling a bit "sharper" since they limit how much the car can lean in one direction.
I didn't notice much or any change when I ran them with or without..Just my thoughts.
Stephen <><
#2462
Originally Posted by Mr. Shookie
Cool but wouldn't that casue push in the front by not allowing the front end to dip in corners...Just trying to clarify. Or is it so each corner doesn't dip too far?
Stephen <><
Stephen <><
#2464
instead of o-rings...these are available from RPM
clip on limiters in various heights.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEU84&P=7
#2465
The shock shaft o-ring can also be use to limit the shaft from hurting the bladder if you set the shock length over 61mm.
#2466
R/C Tech Elite Member
#2467
randy, getting ready to soak some belts, but i noticed on another thread they were talking about the belt expanding and not fitting into the pulley slots, i'm assuming this isn't a problem with the yok belts as you and others are doing it. thanks in advance, oh yea, i have extra belts, so gonna do the two day in cleaner and two day in wd-40 thing.
#2468
#2470
Stephen, I am referring to the thick black O-rings that your suppose to slide onto the shock shafts before threading on the plastic shock end.
#2471
Originally Posted by Randy Caster
What kind of track do you run on?
anyway, our track is a bit square (36meters long by 28meters) , very technical, but the corners are very flowing... traction improves dramatically as the sun goes down.
some people have tried the protoform stratus already and they say its defintiely better than the mazda6... more steering, but still very planted.
thanks - jason
#2472
A locked center pulley and 1 way has had more steering than a locked center pulley/spool in all of my testing, actually by a large margin.
this is what i felt also... seems like the car slows down better with a front 1way and locked center pulley...
#2473
Originally Posted by highwayman
hi randy, this is the first time i got the chance to log on again after a week long absence... anyway i was aking about the yoke stratus E, and you mentioned that it had tons of steering...
thanks - jason
thanks - jason
#2474
Here you guys go a website that has the delrin diff parts.
http://shopping.rcmodel.hk/product_i...oducts_id=6114
Glad to be a service.
Also go to the RCMODEL thread and ask RCMODEL if they are in stock before ordering from there website, they inventory isn't live. So you need to ask before you order...
I just got burned a little bit because I ordered some Sorex 36R and some Yok inserts and because I paid for normal shipping, it takes a couple days for them to get it out and SOMEONE ****COUGH**** made an INSAINLY LARGE ORDER ****COUGH***** 50 set****COUGH***order after me but paid for express shipping and they sent his order out before mine. I got shafted on some inserts, glad I have some extra here or might get a little mad...LOL
But hope the rest of this post helps,,,,LOL
Stephen <><
Stephen <><
#2475
And do you know who this "someone" is?
50 sets is a rather large amount. lol
anybody racing on carpet this weekend? can you let me know how it goes
