Hot Bodies Cyclone
Yeah true but, you'll still be snagging setups off of me even when I don't follow to the EJ car. LOL
Don't swerve on the straight next time! It could be unfortunate....LMAO!!!!
"72!!!! 72!!!! Who's on 72????!!!!!" Screams STLNLST on the driver's stand. "You're on Spectrum dummy", says Advil.... "oh, well, you know, a brotha has got to get his SWERVE on", says STLNLST.
Yeah, ok. My bad. Next time I'll tell them about all the times you yelled out "Oneways!!!" when you actually had a spool in your car!
Hey there
Newbie question, but is Cyclone TC:s bearing set same size like WCE ones?
gearing
I'm currently running the Cyclone Black ver.
I also run 10.5 (novak) LRP sphere tc (the new one)!
My issue is with gearing. The track is approx. 140 ft long on the straight!
I am running the 16T pulleys still and have a FDR of 4.82.
It appears as though after the initial acceleration out od the corner the motor flatlines and runs a constant pace no acceleration. I was watching the TITC vidoes on youtube. It is quite obvious yes that they were running MOD however their cars have "continuous pull" along the straights. Looking at their cars also revealed that the relationship of the pinion and spur gear.
I am running a 93 Spur 47 pinion 64p would it be better running a Bigger spur and a smaller pinion?
The novak 10.5 isnt geared anything like the typical brushless modified motor. They are alllll torque, so they need to be geared really tall like that. Have you checked to see how hot the motor is getting??? Usually around 160 deg F is a happy zone with most of the motors.
-Korey
-Korey
what settings are you running on your Sphere TC with 10.5? Also, I use Orion 4800 16C pack with my Novak 13.5 motor, my car is slower than the other guys...but they are running same gaering as me but use SMC 28C and Trackpower 25C packs...I think my 16C lipos just cant keep up
The temp was 140-150 F after a min run. So 5.2 is the sweet spot? is there any timing advancement on the motor and what profile setting are you using?
cyclone
hi guy's
i am looking for a new sedan been off the racing scene the last 2 yrs
my last car was the rdx .
how do you compare the cyclone vs the rdx
the parts are they stronger then the rdx ,handling parts availabilty etc etc
any feedback would help!!
pete68
pete68
At the KO race I ran the Novak 10.5 with the timing cranked all the way up. The gear ratio we used was 5.2 and the straight was 160ft. It was good enough to make the show and my motor never got over 160. On smaller tracks I usually run between 5.4 and 5.6.
What pinion and spur were you using?
I had the rdx too and that car is real nice on carpet foam but the cyclone tc is more for rubber I tried to do the foam thing with the cyclone but it can't beat the rdx even with the the bmi chassis, but on rubber carpet or ashpalt you want the cyclone, just my opinion on both cars.
Thanks mangoman.
Where i can buy high quality ceramic ballbearing set for my CycloneTC?
