Hot Bodies Cyclone
Thanks but now the site has problems as you cant check out I get a error.
Runtime error in /mm5/5.00/modules/component/cmp-mv-paymentfields.mvc @ [0000000a:0000008e]: modules/component/cmp-mv-paymentfields.mv: Line 97: MvDO: Unable to open '/mm5/5.00/': Is a directory
Holy batman if it aint one thing it's another.............. any one wanna buy a used Cyclone TC
Holy bat man if it aint one thing it's another.............. any one buy a used Cyclone TC
I bought this Cyclone Front Solid Axle (Spool) for my Cyclone S
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61045
But the stock Cyclone S dogbones don't push far enough into the spool outdrives.
Are there other parts I need to put a spool in my Cyclone S?
Thanks.
Thanks.
Purple Screw Kit?
Hey guys!
just curious if anyone knows of a place that sells purple aluminum or titanium screw kits, im super interested in picking one up for my Cyclone
any help is appreciated
Thanks guys
-randy
Thanks guys
-randy
Driveline binding
I have a friend with a Cyclone TC, essentially new.
His driveline has a problem binding up somwhere. For about 1/2 a turn of the spur gear it is "free", then, for about 1/4 turn it is "stiff". This is of course with the pinion removed.
There is nothing visibly bent, nothing visibly rubbing, or out of alignment.
Disconnecting the front drive belt shows that the binding is somewhere in the spur to rear area. The rear diff seems "normal".
Any suggestions on how to further diagnose and solve the problem. With the resistance in his driveline, it's like he's running with a drag brake enabled all the time.
Thanks.
Thanks.
Try realigning the pulley on the centre shaft, it may be binding on the middle deck.
Thanks.
Thanks.
Check to make sure there a no small rocks or debry (sp) in the pulleys (center and diff pulleys).
Thanks.
Thanks.
Anyone?
The small foam pieces that go into your outdrives for the stock diffs should be placed in the outdrives of your spool, thats what I did and I have not had any issues with it!
hope that helps
-randy
hope that helps
-randy
Thanks.
Thanks.
