Hot Bodies Cyclone
the biggest 64p pinion gear I can find is 47t. I ordered it but I want something bigger!
rigjht now my FD: 4.424
My goal is 4 flat
Im using 18t pulley's to bring the DTr to 2.166
My goal is 4 flat
Yes, i can confirm that this ratio works as it is what i use for silver can 540 racing here. If you use a 39 tooth pinion you will get very close to what you desire. I use KAWADA spur and pinion as a local hobby stocks them, but they are also available on alot of the Hong Kong websites.
Good Luck
Good Luck
i just got my moore-speed and I need to knwo if the 2.5 degree pivot block up front means the car has 2.5 degrees of TOE-OUT. It makes sense and I can see the wheels pointing out. I ordered a 0 degree mount, does this make sense?
Super Moderator
look at the attachment
On another note, Has anyone tryed the 3 racing pivot blocks or alum diff?
do they fit ok?
do they fit ok?
Ok, so what if I dont want in-board toe-out? I ordered a 0 degree pivot block for the front, that will make it like most touring cars right?
if i wanted outboard toe out, I would need to make adjustments to the steering turnbuckles, im quite certain.
Also...has anybody assembled the layshaft in a cyclone....holy f--- what a $hitty design.
Whats wrong with it? Just make sure you put it in the right way. Spur goes on the left side of the holder when its mounted. It may not line up with the hole underneath it in the chassis.
i just dont like hwo unclear the insutrctions are during the layshaft assembly. I mean after your done building it you have gaps in between the pulley's and the spur gear on both pulley's. its like you need to align everything up, its wicked stupid, if you built any other TC you would see why.
Most newer TC's have pins and everything is pre-setup with tolerances already set. With the cyclone your basically setting the tolerance by pushing the pulley against the bearing into the bulkhead, you dont know if its binding or if its too loose.
