Hot Bodies Cyclone
#5641
http://rc-mushroom.com/product_info....ducts_id=10991
are these the ones i want for the front?? (runing a spool) just confused me as it says rear.
#5642
I splashed on a cyclone few weeks ago. after racing for few times
my HotBodies cyclone tends to turn right in straight lines whenever I pull the trigger.
First I thought my droop or right hight isnt the same for left and right.
I double checked and all the reading are the same.
I placed the car on a flat surface and lifted the front shock tower by the middle and noticed that the right wheel clears the grounds before the left. which means on throttle the back of the car dives for more traction and the fornt lift slightly resulting in the left wheel having traction and the right not having equal tracion, hence the car tends to turn right.
I checke the chasis and I dont think its tweaked, and as I mentioned the down stop, ride height and droop is the same for the left and right side of the front of the car.
Please, any ideas what could cause this and any cure would be appreciated
#5643
You checked your shock length?
#5644
I setup in order:
downstop
ride height
droop
camber
toe-in
I used gauges for all the above settings
cheers
downstop
ride height
droop
camber
toe-in
cheers
#5645
Originally Posted by brownviper1966
I setup in order:
downstop
ride height
droop
camber
toe-in
cheers
downstop
ride height
droop
camber
toe-in
cheers
#5646
Originally Posted by benoitrdv
Check your diff stifness ;-)))
#5649
Originally Posted by nf_ekt
What are you guys running for parking lot asphalt racing, as far as rear toe-block is concerned. The cyclone I just picked-up has 3 deg. rear and is super planted but I would maybe like it to slide alittle, since I'm using a ton of brakes to get it to break free....
#5650
How much adjustment are we talking concerning anti-squat?
Is .5mm difference between pivot blocks front to rear considered much? In other words - anit-squat.. big change or little change?
Other adjustments (Eg. toe blocks) have a big and immediate impact on car handling. How does the anti-squat setting relate?
#5651
Originally Posted by protc3
the 3 degree block is the one you want.try a little anti squat.this helps you get into the corner a little better and plant the rear under acceleration.shoot me a pm with your setup and i will be able to help a little better.the car will have a ton of steering once you get the right setup.
#5652
Super Moderator
It's MarcosJ 's old cyclone, so I'm sure you've personally done some set-up work on it already . Trust me the car is real good but I just want the rear to rotate alittle more. What would you adjust/change first ? Oh I like the spool!
#5653
Will these work on a cyclone/ cyclone s ? If so, do I need to change me diff cups or anything? I actually have the cyclone s.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGNY8&P=7
#5654
anti squat is a pretty drastic adjustment.i dont use it often but sometime i need to..5mm higher in the front hinge pin block on the rear arms in going to make a noticable change.i havent tried any more than that.with anti squat,it allows the rear of the car to unload the weight quickly off power.when you get back on the throttle,the rear arms will resist squat and transfer the weight to the wheels instead of being absorbed by the suspension.
