Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 10-26-2005, 07:11 AM
  #1606
I had a crash with oneway and had the same problem as you with the black HB shaft.
The Titanium ones are strong and also very very light.
You should take a spool, the car is great with.
You can check hara's setup on the hpi website.
Hugo is offline
Old 10-26-2005, 07:17 AM
  #1607
Trader Rating: 16 (94%+)
yep mine are also slightly bent, and twisted, ie. the pins at either ends no longer are lined up, by nearly 90deg, this has also happened to other cars down here, they seem very weak, even weaker than the regular hpi pro4 cvd's. (i am using a one-way)
domo is offline
Old 10-26-2005, 07:26 AM
  #1608
Teddy's Avatar
Thanks Hugo.
What you suggest? US Spec or Pro Competition spool?
Teddy is offline
Old 10-26-2005, 07:33 AM
  #1609
It depends on what you want, If you run an open track the Pro spec is ok but if you run a carpet track where you can crash easily, the us spec is ok.
Actually what you can buy the us spec that last a long time and buy one or two pairs of extra delrin outdrive (the spool is the same for us spec and pro comp, you can exchange outdrives).
I have the pro comp and there is no wear and the quality is top notch!
Hugo is offline
Old 10-26-2005, 07:48 AM
  #1610
Phil C's Avatar
Originally Posted by JonboyGB
Annoying that isn’t it.
I’m hoping that Mirage will follow CML and have a section on there website for set-ups, manuals etc.
Here’s hoping.
Ill see wat i can do mate
Phil C is offline
Old 10-26-2005, 01:48 PM
  #1611
I know you have all seen lots of pictures by now, but I thought I would show you my Cyclone with the Nosram Brushless installed. Took some fitting - not much space!!!
crangon is offline
Old 10-26-2005, 01:53 PM
  #1612
thecrow2k's Avatar
If I may say, thats one smart Cyclone, I notice you haev the JET transponder holder, just a few questions.
1)Do you use it for PT's?
2)Is it made for PT's or Handouts?
3)How is it held to the speedo?
4)Will it hold a Handout transponder?
thecrow2k is offline
Old 10-26-2005, 01:56 PM
  #1613
rc-zombies's Avatar
I have something similar...
1) yes it can be used for PT's...you'll have to secure it with
servo tape and mount underneight.
2) both.. I have PT mounts that looks like handout transponder
and clips the same way.
3) servo tape or shoegoo
4) yes.
rc-zombies is offline
Old 10-26-2005, 01:58 PM
  #1614
thecrow2k's Avatar
Thanks, If Im ordering from RCMART I may pick one up
Old 10-26-2005, 02:08 PM
  #1615
Wink
worth getting one, save drilling holes in shells that I hate!
crangon is offline
  #1616
rc-zombies's Avatar
if you're using a PT..just do what Hara does...use scrap Lexan
Old 10-26-2005, 02:09 PM
  #1617
oh, and all the questions are all ready answered by rc-zombies, thanx!
crangon is offline
Old 10-26-2005, 02:10 PM
  #1618
fjm9898's Avatar
Trader Rating: 11 (100%+)
wow these cyclones are looking great guys! now i just need one of you to get bored with it and sell it used so i can buy one i am to broke to buy one new lol. one day ill have one...
fjm9898 is offline
Old 10-26-2005, 02:24 PM
  #1619
floodo1's Avatar
me 2
floodo1 is offline
Old 10-26-2005, 02:27 PM
  #1620
nordheim's Avatar
All ready to go. It was an amazingly easy assembly. Took just a few hours to put it together.
Looking forward to throwing the electronics into it and taking it for a spin.
Good thing that it is this similar to the Pro 4 as I had just painted a new body for my Pro 4 before getting the Cyclone.
Attached Thumbnails Hot Bodies Cyclone-dscn3011.jpg   Hot Bodies Cyclone-dscn3010.jpg   Hot Bodies Cyclone-dscn3012.jpg
nordheim is offline
