Which brushless motor?
Need suggestion on which 17.5t and 13.5t motor to go with. So far I've narrowed it down to LRP X12 or Thunder Power Z3R-S. Is there any particular advantages between the two (is the LRP worth the extra cost)? When is the x20 for 17.5t or 13.5t coming out.., or is it already available?
Other motor suggestions are welcome, but these two are readily available @ my lhs. If it matters at all, I'll be using it with a Tekin RS Pro on a TC6.1. Thanks for any help.
So I'm guessing the X12 timing can be adjusted so long as you use these timing inserts.., correct? Do these inserts come with the motor or will I have to buy them separately? Is there a particular motor that will run better with the Tekin RS Pro? Thanks for answering sOme of my questions, trying to get started into club racing.
It seems for 17.5t it really doesn't matter which current motor I go with, more like a matter of brand preference. Does this apply with 13.5t motors aswell? Ill probably end up grabbing thunder power for 17.5t and maybe the x12 for 13.5t. Or should I wait for the X20 13.5t to come out?
