2013 Torque line by Picco
#347
Well unfortunately our 2013 HOA series season has come to a close here in the Midwest.However my first experience with a picco engine was a HUGE success.For anyone out there jumping from forum to forum trying to decide which engine to go with I would highly recommend this one.You won't be disappointed. I want to give a special thanks to Kevin at Kevco racing for his outstanding customer service.Thanks guys for a Great product and some awesome help.
#349
Hello , i tried to put Nova carb on Picco it doesn't fit . Nova is 15 mm and Picco os 14mm i think it need to be modified .
#350
I always use Nova carbs on my Piccos. It just needs a 5 minute session on a lathe, and it will fit. Nova carbs are much better in my opinion.
Just put it on and you will hear the difference, even on the starter box!
The engine will respond better with 9 mm restrictor, opposite to Novas which usually improve just on hi revs. Piccos gain torque always from low to hi rev, when using larger venturis. Bench tested.
ciao
ciao
#352
ciao
ciao
#354
Examples; They still build "Rally/GT" engines, they have "Speed" (probably Tether) engines and they even made a Helicopter engine a couple of years ago.
#355
the engine which tadahiko sahashi using is different carb compare to picco web,i have use navo carb with picco engine before,better idling and easier engine setting
#356
What I meant is that their website isn't the best source for information regarding their products.
#357
I have been running Picco and REDS engines for 4 years now and never but once had a carb problem.
I find them easer to adjust than a friends Novas....
#358
+1 on Picco carbs, we are running Reds. Its a strange feeling spending time racing and not chasing tune.
Such great engines really!
#359
Every engine there is hand built and controlled and Mario Rossi puts his personal touch on the carbs.
I never had a more relaxed year regarding engines than this year.
Every engine ran solid as a rock, no ups and downs and all the engines are on the same power level, which is really high.
#360
2013 "World Championship Limited" edition
Here's the 2013 "World Champion Limited" edition. Only 150 available worldwide.
Engines will arrive Nov 7! kevcoracing.com
Features: New aluminum carburetor, piston liner design
