Team Much-More cell master v1
#1111
I am sure James or a few others can post more info. But there are rumors of a new Li-Po only charger swirling around the NW. It is due out 3-4th quarter from what I have heard. Not sure charge rates, features but I have heard t is coming.
You can also charge your Li-Po currently with your cell master just not at the higher rates that others are starting to use now.
#1112
just out of interest what CTX settings is everyone using
to charge thier IB4200SHV cells?
cheers
cheers
#1113
Originally Posted by nnick
You are using way low delta peak settings for this charger You should use something at the 20-30 range depending on the batteries and ambient temperature.
Nick
Nick
Could someone post some peak detect settings for some different types of cells?
I've running Eastpower (infinte power in the USA) 4200's, IB4200's and Peak GP3700 David Specials.
#1114
I use for all 4200's "06".
#1116
Originally Posted by Runin Ronin
I just got several match SHV IB4200 packs... Any have a Charging profile for these cells??? I checked Nexus Racing, and they do not have one... yet.
Note: For IB4200SHV cells, we recommend a standard linear charge. The linear charge will allow you to take full advantage of the VERY high power and run-time already offered by these cells.
#1117
cheers
cheers
CTX Step 1 - 7A to 3000mah
CTX Step 2 - 7A to 3050mah
CTX Step 3 - 7A to 5000mah - 03 cuttoff, 50 degree cuttoff
Repeak in Linear @ 7A with a 10 cuttoff
#1120
This is not that uncommon...
CTX profiles are locked against delta peak (but not temperature cutoff) in the first two steps, so you can use a linear CTX charge to set a long lockout by mAH instead of by time. I assume this is why FTNTC3 sets his CM this way.
#1121
Oh, and a linear charge works awesome for IB4200SHV cells. On the track, the cells feel like they maintain a relatively flat discharge curve with great power, even when charging at high rates (~6.0-6.5amps) for modified racing. I tray them to .60v before charging with the CTX-D in 5A linear mode.
#1122
#1125
