New Sakura XI
#346
I was considering using it for drift and wanted to know what my options were if I did decide to. I found the front one way.
I know I can tighten the ball diff and make it a solid rear, which is good, do you have a parts number or location I can find the ball diff, a brief search came up with something from R2 hobbies but that does not look like a standard ball diff to me
Is this the only option for solid rear axle or are there others?
#347
What did you mean by spool? I dont want a slipper style setup I want it to be a rigid/solid rear, why wouldnt I just make the ball diff tight as all get out?
#348
Whoa that went over my head. I have never actually used/worked with a ball diff, ive only seen them and actually own one for a ta06 but never used it and dont plan on using it.
#349
hi guys,
I'm looking at this XI, but there's no LHS in our country that carry parts, what are the parts that will most likely break or wear out fast that need replacements? Or i can use tamiya parts and not to worry?
New with touring cars, and thanks for any help i can get.
#350
There is a spool. 3 racing calls it a solid axle. you will need the solid axle, outdrives, and the pulley for the belt. It fits up front so it should be fine in the rear as well. You can use the existing rear axles but I would recommend getting rid of the dog bones and go with the cv drives.
http://compare.ebay.com/like/3606203...Types&var=sbar
A set of these...
http://www.integy.com/st_prod.html?p...20&p_catid=326
or could I use the ones that come with the kit?
and one of these...
http://www.integy.com/st_prod.html?p...37&p_catid=326
I dont have the XI, I have the XI Sport, it comes with universal drive shafts in all 4 corners.
Please let me know if I am correct or what I actually should be getting if im not.
Thank You
#351
So what your saying is I will need to buy 2 of these...
A set of these...
and one of these...
Thank You
A set of these...
and one of these...
Thank You
I don't think the out drive cups come in the kit. they are different from the ones used in the gear diffs. (Second item you listed)
Correct on one pulley.
#352
How are the outdrive cup pins held in place though?
Also I want a front one way, so wouldnt I need two of the axle spools, one for the front and one for the rear?
#353
Im not sure on the one way. haven't used one of those yet. Sorry.
#354
http://www.rcmart.com/3racing-front-...=595_1419_1467
#355
I got my answer, because then I wouldn't have reverse if I wanted to use it.
Beyond that, has anyone had any issues with belts breaking?
#356
Finally got the rear end to stick Just had to soften rear end more than I thought I should - can finally start to tune this car properly now - thank goodnes it has proven very durable during this difficult phase - have yet to break a single part.
#358
Has anyone tried the new Ultimate yet and if so how does it perform compared to the XI
#359
Anyone still on the Xi and Xi d.h. ?
I am still driving these and am curious about the coming indoor events and how the Xi d.h. can perform this season. Last year I got the problem that i lost too much cornering speed along with less steering through the whole corner. Anyone got ideas on how to solve this?
GTS
GTS
#360
I got the ultimate but haven't started to build it yet.
