R.C. tires...
#31
the biggest thing to inside carpet racing is alot of tracks have gone to an odorless traction compound. these compounds your putting together can they be odorless?
#34
Some of the additives I tested would probably classify as "odorless", others smell like a paint factory.
Skiddins- As I understand it, the "tire wash" is to remove the treatment from the tire, without drying it out, probably between events. I haven't tried it, just used the clear stuff [HT Series 1] to clean tires, gets rubber build-up off the tread quick, fast, and in a hurry!
I'm interested to see how these preps work on asphalt as well.
Also, I think I need to correct an earlier statement: New scuffed tires are still faster than used tires, but the additives we tried on used tires dropped about .2/lap compared to the regular additive we had been using. As pleased as I've been with the sauces I've tried, it's not magic, but it has helped to get a few more competitive runs out of a set of tires.
#35
R/C Tech Elite Member
So which one would you recommend I order to try on asphalt? Talking FTS here.
And this one you already tried?
http://www.amazon.com/gp/product/B00...F8&me=&seller=
#36
For FTS preps, I'm very confident the Clear [HT Series 1] will work well as a cleaner and light prep.
For more grip, I would have to experiment between Light Blue [HT Series 2] by itself and the Red [Slight Bite], cleaning with one of the HT Series preps, and using the Red over top after drying.
The Black [Black bite], took a long time for the tires to "come in" on carpet, but this is the sauce I'm most interested to try on asphalt, again, cleaning with either clear or light blue.
#37
You guys should try
Trinity Traction Tire Tweak 2000
TTTT 2000
TTTT 2000
