Jammin X1 - so close yet so far
#2162
Originally Posted by Tabushi
Guys,
Anyone knows an alternative boot/cover system to use on the big bore Jammin Buggy Shocks ?, i did my shocks last night and man, after 2-3 weekends the silicone was full of dirt !!! arrghhh thats sucks ... if i dont get an alternative better system for controlling that, i will have to rebuild my shocks every weekend in order to use them always clean on the inside ...
Help please,
Help please,
I also use a surfboard wax on my shocks and suspension components- keeps dirt from clumping in the arms, between the shock and tower. etc- makes cleaning easy.
BTW, Tabushi- Most people re-build their shocks EVERY weekend. I do, at least, and most pro guys do. Sure, the oil may not be bad, but........
#2164
The std big bore dust covers work fine if you clean the felt on a regular basis.
#2165
Originally Posted by macnkitty2002
you all rebuild your shocks every weekend? i do it about every 2 months. what's the point of doing it every weekend?
#2167
Eaxctly my thoughts.
#2168
about rebuilding shocks, i've had awesome luck with using baloons to cover the shock shaft and haven't had dirty shock oil unless a baloon has ripped. this isn't just with my jammin shocks (only 1 race weekend on these) but with mayhem shocks as well (full season on these). all i've ever needed to do after a race weekend was add a little oil to the shock because a little has leaked out past the o-rings. but because it's covered by the baloon, no dirt gets in. i took apart my mayhem shocks 2 weeks ago after putting 3 race weekends on them, just adding a little oil after each weekend, and the oil that came out was still very clean. i'll put another race day or 2 on the jammin shocks and see how they fare. from what i've heard, they are a little better.
#2169
The Jammin shocks aren't the best I've seen- The o-rings and bladders hold up nicely though. One thing you may want to check, Adam, is the C-Clip retainer in the bottom of the shock. I blew one of those out every once in a while, and it just became a habit to check them after every race.
#2170
Ballons! Where ever did you get that idea? Been using them for over two years, I gave the $10 boots the boot.
#2171
Hey guys what is the easiest way to put the balloons onthe shocks? Any special way to do it?
thsnks
thsnks
#2172
How often do you guys replace your universals? Every six months or so?
#2174
2 months? Thats crazy. I take it you dont like a consistent car. My shocks oil is pretty bad after one raceday it must be mud after 2 months.
no, i like and have a consistent car. i don't rebuild them every weekend but i do remove them, thoroughly blow them off with high pressure water and an air hose, spray a little oil around the seals on the bottom, and then replace them. by the way, i race on a dusty track, so the dirt doesn't stick to your car that much. i used to rebuild my shocks about every 3 weeks, but i found that the oil was fine and the oil itself started to take its toll on the wallet too.
Has anyone tried the new lightened universal shafts?
