Team Losi JRXS
Originally Posted by Slippery Dan
Thanks for the info on the a-arms.
Are there any aluminum hop-ups for this car?
Dan--Just the PRS aluminum gear adapter and the suspension blocks by Losi that I know of.
Brant
Originally Posted by tom235
were can i find this set-up? i would love to try it,because i don't like the set-up i have on it now
http://www.rctech.net/forum/attachme...hmentid=170703
thanks i will give this a try and report back
Juan Valdez is this the same one your running
Juan / Tom235 I have run my rubber car at an event since Vegas a few weeks ago....made a few changes to suit rather high traction....
I ended up ditching the rear sway bar, and just using the regular bk lower hole on the arm, as well as the #4 camber link spot up front...similar to the stock middle hole. Also the rear diff low.
It proved to be much easier to drive, and much more stable / predictable....i am not sure how it will work on lower bite though, so yo could try it if your looking for a little more on the track.
did numan setup use antidrive?? (2 shims on the front block)? cause i think while i was rebuilding my car, i did something wrong, it has 2 shims on the front suspension block both front and back , and when i put back the a arms, i could not get a play. it will hit the outdrive. . is there something wrong?
Wil--make sure you have the blocks in their high position. Yes the Numan set-up calls for 2 thick shims under both the front blocks. couble check it and let us know.
Brant
Pookyt, thanks fo rthe clarification last night on how this stuff works. I looked at the car today and honestly don't have any idea how I did as well as I have done with it. It was so not the right as far as the roll centers, front and rear!! Now that I have the insight with what you provided me with, I shall make it right and see what happens this weekend. Hell, I may find a renewed love for this car!!
She's been completely rebuilt and had the chassis re-sanded and sealed.
I don't want that car back for I only want one of the old cars and one of the new ones if it ever comes out. I have plans to keep the old car for rubber and the new one for foam. Hell, I probably had that car setup wrong too since I had the same setup on both. So it is a good thing you went over it anyhow.
I've decided (for now) not to mess with the Type R. This car is really good and I really don't plan on running much TC as 12th is my main class.
Blake
Actually there was one thing that was SUPER jacked up on the car you sent. The lower shock mounts (on the shock shaft) were different lengths. It messed up all kinds of things and made it difficult to setup.
I have seen on many peoples JRX-S's on the upper decks there is the countersunk screws with the little circle countersunk washers. What length screws do you use and what size countersunk washers do you use?
They look cool so i was thinking of doing it to my car to.
