"How To Properly Build And Break In a Ball Differential and Slipper Clutch"
#316
This is a fantastic thread! I was wary of building my first ball diff on my new 22, but after reading through this I put it together and had tremendous success at its first two race outings. Thank you very much for the information.
#317
Was wondering if there is a (urgent) need to replace thrust washers after a groove has developed in them. I use ceramic thrust balls (B-Fast).
I understand diff rings need to be replace/sanded/flipped after each rebuild.
There are thrust ball bearings where the thrust balls are seated anyway, so is it necessary to replace grooved thrust washers?
Thanks,
Thanks,
#318
On the old Losi XXX-T we would tighten the diff screw all the way down, and then back it off 1/8 of a turn. Do it again after a couple of runs and check it from time to time. My diffs lasted forever and were very smooth that way.
#319
Wow. Pretty comprehensive. Thanks for the great videos. This certainly help me a lot.
#320
Hi! After failing at building my first ball diff, I followed this guide and it solved my diff barking problem after rebuilding it! Thanks a lot.
Just a question, I'm running stock motor and when I follow your procedure in setting the slipper clutch I can't get the frot wheels to go up to about 3 inches. I tried tightening the slipper clutch already but after a few tries my motor became very hot and some smoke started to appear (good thing I stopped as soon As I saw this, my motor is still good).
So what I did was to just tighten it so that it doesn't slip when I throttle and hold both wheels.
I checked the diff and i think it is tight enough (when I hold the right wheel and spur gear, the left wheel can't be rotated w/ moderate force). The diff is smooth when I do counter rotation on the wheels too.
Did I do something wrong? Or is this expected for a 17.5 motor (=no wheelies)?
#321
#325
Sorry for all the probing questions, but Im trying to calculate your rollout ratio. The rollout ratio is the ratio between your motor rpm and your rear tires rpm. It should be 1:1....one turn of the motor should equal 1 turn of the tire. Anyhow since I dont know your motor, I'll just assume it's roughly at 2500 kv which is common for a 17.5T motor. Knowing that TLR kept the same diff as version 1.0, this gives us a diff ratio of 2.43 (see your manual).
Finally, let's just add to the assumption that your tires are 3.35" in dia, and with a 70/32 gear combination this gives us a rollout ratio of 1.98. At 8.3v your 22 will hit 38 mph. Unfortunately, you want a rollout ratio of 1.0, so the bottom line is your overgeared for that motor. Ideally a 17.5T motor will be very happy with a 76/18 combination and this roughly provides a rollout ratio of 1.02 at a top speed of 20 mph. Now this can be stretched with either a taller pinion, and or timing via the endbell or the esc but doing so you will need a temp gun. Because once you start to deviate from 1.02 you'll start raising the temp of the motor/esc/ batteries. A temperature of 180 degrees F seems to be the accepted upper limit. Beyond this temperature you start to cook the glue that holds the magnets inside your motor.
Bottom line, you will have to upgrade your motor to give you that top speed of 38 mph. It's surprising that the manual gives a 70/35 combination since that's a rollout ratio of 2.16!!!! With a top speed of 43 mph!!! It's got to be a typo. For that type of performance your looking at a motor with 8.5T or a 9.5T geared down for torque to keep things nice and cool. The version 1.0 manual calls out a 76/30 combination, and that gives a rollout ratio of 1.7 at a speed of 34 mph. That's more believable, but I'd still take a temp gun to it just to be sure. It is really strange to see 70/35 for the v2.0 since they added so much weight to it also.
Do a google search for "rc rollout calculator"....
Have you taken the temp of your motor after a 6-7 minute run through a course? If so what did you get?
#327
Let us know what the temps are....remember moving forward on the track at speed helps cool the motor, as oppose to it just sitting in one place with the rear tires held down.
#329
Sounds like a rockcrawler setup.
