Ask Steve "The Evicerator" Weiss
#7053
SKUBA
#7055
The Evicerator
Woohooo!
#7057
Steve,
I'm having thermal issue with my 2 weeks old Havok Pro, like stated in other post, the thermal cut-off cut below 140
I think in the past we could cut the blue sensor wire or something like that. Is there a quick fix other then sending it for an upgrade?
Thanks in advance
Thanks in advance
#7058
The Evicerator
Good thing I wasn't picking my nose or anything
What LEDs are blinking when the shut down occurs? How long does the shut down last for?
You can try removing the blue wire from the the motor's sensor harness and insulating it with heat shrink so it doesn't short out against anything. ( I wouldn't recommend cutting it)
If that doesn't help there may be some other things at work.
Steve,
Thanks in advance
Thanks in advance
#7059
Steve, have you been able to get some runs in with the Kinetic ? Are there any scraps of info you can drop us until the Kinetic is released ?
#7061
The Evicerator
We've been running and testing the Kinetic for a while now... I can let you know that testing has gone well so far! The ESC runs cooler than the GTB did and many of the new features/adjustments are working the way we want them to!
We are in the process of polishing up certain aspects of some features but things look good!
Let me know how it goes with the blue wire removed! If that doesn't help there may be some other issues at play and we can delve into them then!
#7062
Steve -
With all of the banter in the VTA thread about 25.5 motors, would a 4 cell GTB be safe to use with a 2s LiPo and a 25.5 Ballistic? The big issue with the 4 cell GTB is the lack of heasink and fan, right?
#7063
The Evicerator
You should probably be alright. Just be sure to check the temperature of the ESC and make sure it's not running hot!
#7064
Good to hear that the new ESC is working as expected, I'm in the market for a new ESC to share duties in 10.5 and mod so I'm hoping it's still going to be available soon. Like maybe the middle of January
#7065
happy new year
Happy New Year Steve !!!
Just wondering when you going to come out race/ practice ? I'm still running your set-up but waiting for your update...and Barry needs someone to beat him!!!
