Kyosho v-one rrr
#7788
Whats up Dom.
Great Job with the Isssssland hobbies plug. I am sure Ron is very happy about that
And John show`n somd K support in Canada!
#7789
Originally Posted by jjmudd
I have been helped!!!!!!!
Thanks for all the info and ideas guys. It has payed off in spades and I will be running this weekend!!! I'll keep you posted as to how the V1RRRWC fairs up North!!
John
John
#7791
i'm having problems with the cluth engaging too late, first had the cluth nut at 1.5mm and was engaging at 1/2 throtle, now at 1mm it engages at almost 3/4 throtle, i'm doing something wrong? what could be the problem?
#7792
#7793
Originally Posted by drfritz
Is the clutch bell shimed right? .5mm is what it should be.
#7794
Location: Costa Del Sol, Marbella, Spain www.bradir.net
dogbone
Thanks suntok2,
I just bought 4 Sirio PR .21 Pro engines from Ricky at Dogbone!!!! Man, he is fantastic to deal with!!
John
John
yes indeed
#7795
everything is installed like the manual says and shimed right, somebody told me to replace the spring for a softer one from mugen....
#7796
#7797
Did you double check that plate, only because I did do that, and the car preformed just like that.
#7798
make sure your clutch nut isnt loose - the one that you first screw on tight against the flywheel, if this comes loose you also rev and go no where use loctite if you didnt on it already.
#7799
Keep us posted on your results.
#7800
everything is installed like the manual says, i loosened the cluth nut a little bit and it engages like at 1/3 throtle but looks like it is slips, disengages and with a little more throtle engages back again.
