Kyosho v-one rrr
#6826
Originally Posted by antoine80
what tires do you use? not shore but company.
my local distributor brings tires from Jaco, do you know the company? i have heard a lot about Enneti tires what is your opininion about them?
#6827
Originally Posted by SOLOARTIST 702
R/C PROSERIES PRICELESS
#6828
Originally Posted by mrgsr
hi guys
i just wanted to ask a question regarding the rear shock end ball cup.
the manual says to use the small ball end. however when using small diameter tyres there is not enough thread on the shock body to gain the right ride height.
on my previous rrr another racer once told me to use the medium ball end.
is this the right thing to do ? i just want to make sure this rrr is built as per the book from the beginning.
#6830
Originally Posted by rmdhawaii
Painting and final fitting are done. That only took all day.
If I have time after working on my car tonight, maybe I can add some decals.
ROAR says 50mm max.
#6831
Originally Posted by Osiris 75
Would you all prefer a front differential??
#6833
Originally Posted by jag
Not only can you not get enough ride height but I wasn't getting any droop. The shocks were too short. I installed the mid-sized ball cups and they work fine.
#6835
That hole in the windshield looks rather large.
ROAR says 50mm max.
ROAR says 50mm max.
#6836
Originally Posted by performula
For some reason I only get 4mm droop on the left rear arm with the shocks taken off and about 6-7mm of droop on the right rear arm. It's weird because there isn't any binding.
#6837
Originally Posted by joemugen
maybe you are not using the right set screw (that lifts the arm that creates the droop). if the set screw is too small, it wont push the arm up high enough. my 2 cents.
#6838
Sorry officer. I know the rules say 50mm max (not really), but I guess I wasn't paying attention and before you know it, I was over the 50mm limit. Can I just get away with a warning this time? I'll be sure to keep it at or below 50mm next time.
#6839
It's not the screw because I took them out when frustrated with another issue. It's limited for some reason.
Could it be the plastic on the knuckle, where the pivot ball comes up got jacked and limiting travel?
Dom
#6840
did you ever get that telemetry system going??? if so, how did it work?
Got the temp sensor working this weekend, which was great. Fabricated some clip-on brackets so that I could easily remove the recorder and attenna after I was done tuning. I don't want it on the car when I'm racing. I'm probably going to buy myself the optical RPM sensor, because I don't want to attach magnets to my new lightweight flywheel. I also need to buy myself a notebook ($200 for a leased returned Dell on ebay).
So far, so good.
