Barracuda from Alex racing
#2686
OK I found what was probably my big problem with the car spinning when coming out of corners.
It seems one of the diff plates managed to move and deform the delrin it turned about 20degrees and has pushed up two lumps at each of the flat sections in the delrin which must have been rubbing on the diff gear, causing it to bind a little. Just enough to make it like it's occasionaly had rear wheel drive.
What a pain, I have no spare diff halfs. I'm going to have to stick to a one way in the front and put my extra diff in the rear. I've trimmed the lumps off and I'm glueing the plate one, just so I have an emergancy diff, should work since the Lab diffs don't have the flat sections to hold the plates it just uses glue. Good to know my setup can't have been that bad, nor my driving....
Now do I wait until I need a load of bits or do I order one part to get shipped internationaly
#2687
Originally posted by Tsubasa Sakai
For Pal R1,what is the minimum weight I should add on the electronics side in order to balance the car?
if you are using a TC2 Novak and 3000 panasonic`s then if woould be 10 grams tops...
-Dave
#2690
R/C Tech Elite Member
Johnbull - I think you should try ordering an R2 from Speedtech, just to see how you like it. It seems like the Barracuda is starting to get known more out here, and definately proving itself with winning the KO race, and 2'nd place at Reedy at my home track, SoCal Raceway. It seems to be the car to have for stock racing, so since you run stock, it seems to add up just about right
#2691
-Dave
#2693
PM back at you TS..
PM back at you TS..
#2696
Any idea what the TBA in my signature can be replaced with yet Dave?
yes I get one more chance to break one of my Barracuda`s ..Hopefully the Novice people will have there own class tonight...plus it`s Saturday Night..and there should be a good turn out...I`ll let you al know how it turns out
-Dave
#2698
Awesome Dave, good luck at the races... sucks that there's a 16 hour time difference between us, but I'll be able to change my sig in the morning. I'm so anxious to get this car, I'm a kid in a candy store right now
I`ll have more pic`s from the races tonight and all of the local users Barracudas tonight..
-Dave
#2699
Sup Dave,
Can you still hook me up with a Web R2?
#2700
Originally posted by elnitro
Sup Dave,
Sup Dave,
