Futaba 4pl busted
R/C Tech Elite Member
The 4pl has great features but is very poorly put together, these stoppers snap if you sneeze within 100 ft of the radio and Futaba will screw you on warranty with this (well Futaba Aust did anyway) as they like to call it "physical abuse".
If your gonna glue it ...glue it with the case off ....i made the mistake and glued it with the case on and the ca got in the wheel spring and then it wouldnt return to center on its own
Maybe Futaba QC is going down, but...
I've used a 9550 servo for 3 seasons of racing, not one issue with it.
I also have a Futaba 3VC transmitter and the original reciever/xtals that came with it AND the original nicad pack circa 2001... Yep, you guessed -no problems with it at all!
Sounds like the moulding material has changed
it seems to me this is the most common problem with the 4pl i just bought one gonna be here in a couple days i almost got the m11 it was only a hundred more and had fasst so the feature that the 4pks has but each receiver was $100 vs the futaba $39-$49 receivers , ive held a 4pks and m11 i liked the 4pks more so im hoping this has some of the same feeling the m11 just seems like alot more than i needed i wanna keep it under three race classes owned at once so $300 in receivers just didnt feel good knowing i can pay the same price for the transmitter
