engine break in process
hi im new to nitro and i just ordered a KYOSHO INFERNO MP 7.5
SPORTS RTR
and is there some specific way to break in?
like few tanks while being idle
few tanks while going slowly driving in a figure 8
few tanks while goin a little faster and so on?
thats kinda wut i remember what someone saying
SPORTS RTR
Motor break in
this seems to be the most popular method now days.
Try the "Bess" Method (Credit to Stephen Bess)-
From the very 1st time you start your engine, plop the car on the
ground & begin running it in a parking lot in 2-3 minute intervals,
tuned only *slightly rich* getting the temps up in the 200F range on a normal day. Every 2-3 minutes, shut the engine down & let it cool completely with the piston at BDC , and then fire it back up; continue this cycle until you've run 15 min or so, and then bump up to 3-4 minute intervals. Vary the RPM and don't be afraid to get the temps in the 200's. What you want is heat cycling of the components without the incredible stress that comes with breaking an engine in when it's overly rich & cold. After cycling the engine in this manner for about 20-25 total minutes, it'll be ready for the track and race tuning.
Many of today's fuels don't produce much smoke, so using that as a tuning guideline is outdated.
Just don't let the engine get too hot, and don't keep the engine at the same RPM for any length of time.
I would not add oil to your fuel. It's possible and it will lube your engine, but it will also make the engine run much hotter. Today's top-brand fuels include very effective oil packages that don't require extra oil to protect your engine.
is it bad if my engines only seems to want to run at full speed? During break in, the car went crazy and locked on full speed during and now it doesn't seem to want to start?
grindog - Your engine sounds like it may be too rich, and your idle may be too low.
If it was stuck wide open until it shut itself off, you have may ruined the engine.
GReddy - All carb adjustments should be in 1/12 turns, or "hours" (think of the hours on a clock).
Once the engine is broken in, tune the top end for a nice, healthy sound, and good top speed in the environment you are going to be driving your vehicle. Once the top end is set, dial in the low-end needle for crisp acceleration with no studdering or hesitation. Use a good quality temperature gauge or probe to make sure your engine hasn't exceeded 240 degrees (an acceptable range for most engines; some, such as the original TRX .15, will run as hot as 270-290).
Adjust your idle a little on the high side when the engine is first fired up. If your engine is tuned correctly, the idle should drop as the engine heats up.
i like the method of break-in mentioned above i do the same thing except i will run through an entire tank at a time
and i tune for 200F i dont want it any colder than that and not much hotter
the needle valve thingy is the high speed needle it may be the only adjustment needle on that carb
you should probably get a temp gun of some sort they have some neat little ones that only cost about $30
for break-in 200F is great after break-in temps between 230-270F are pretty normal for .21 engines
you wanna tune it so it sounds fast and crisp but beware of running overly lean thats why you oughta get a temp gun some engines will just keep getting faster and faster all the way into the 300F range and thats not usually very good for an engine
blue thunder i believe makes a fuel that when run too lean will cause the engine to run poorly letting you know youve got to richen it up
but the best thing you can do is find someone who has experience to come out and help you because experience is priceless when it comes to engine tuning
Blue Thunder, nor any fuel, as any built in "warning"..it's not possible.
www.tempgun.com sells very accurate mini temp guns for around $30.
you may be right about the fuel but they have advertised it
