3Racing Sakura Zero S
#346
Does anyone know if the swing shafts and cross pin/coupler from a Sakura Zero will fit into a Tamiya axle?
Reason I'm asking is i was told they fit but turned out the Tamiya coupler (part with the set screw) is too big for the hole in the sakura 46mm swing shafts I got.
I have a couple of pairs lying around and need universals for my FF03 but have no parts to compare anymore.
Thanks!
Thanks!
#347
Spool measurements
Hey guys,
I was wondering if anyone would know if the sakura zero's spool would fit in a hotbodies tcx? What r the spools measurements in length without the outdrives on?
any help would be appreciated!!
#348
Hi Guys!
Just bought a Sakura Zero S for my Cousin to start running TC - I will be installing a 540j so he can run the Novice/540 class at our club.
I'll be ordering the recommended upgrades in the next day or two, but wont have the car then, so if someone could please tell me what size Uni's go in the rear it would be great, as I'd like to order those too.
Thanks in advance.
Thanks in advance.
#351
which means, 44mm is for narrow sus mount..?
i used narrow sus mount at rear already...
but using stock shaft which is dog bone..
for the front,im using 46mm...
planning to change front sus mount to narrow sus mount..
so i will need 44mm universal shaft for both...? rear and front..?
abit confused here...
#352
Why do you want to narrow the front??
It gives you only less rear tracktion if you narrow the front suspension.
With a gear diff you can you can use the 46mm in the rear but with a ball diff you get binding when running more then 1.5 neg camber.
At the front i didn't have any problems yet with the 46mm axles.
regards Roy
regards Roy
#353
regards Roy
regards Roy
#355
Setup
Hi Guys.
Ive been testing my sakura on some flat asphalt with 13.5 boosted to get the front/back ballance right and ive noticed something that might help.
The front is real twitchy at high speeds and i think its the front top link is very low on the inner causing too much suspension movement at high load, i raised it about 2mm and it was way better and far more stable.
#359
With a 8.5 you want to be around 6.5-7.0 fdr.
48p = 25 pinion 80 spur
