Xray T3 2011
#3421
Skiddins
#3422
I have a question for those of you running the gear diff in the front of the car. Why? Not be a smart-*** but what is the reason specifically?
Most of the setups I have read where people are using a gear diff in the front they are putting cleaning putty in it. I have never used this stuff or seen it personally but in my reasearch people are using this stuff to balance wheels as well. Now to me that would suggest that this stuff is more like a real putty and would not allow the diff to function at all.
So, does the diff work as a diff at all? What does it actually do?
#3423
An almost fully locked diff will act like a spool, except it will have some give in the event of a hard crash. Whereas a spool, with the same impact, may break.
#3424
So basically it is just a spool that has some give in the event of a crash?
#3425
I run a gear diff in the front with OFNA diff lock running mostly 17.5 boosted. I find the gear diff in the front gave the car a touch more steering through the center of the corner as opposed to the spool. It gives a car a different feel, not necessarily faster but I prefer a gear diff then a spool.
#3426
Some tracks it's better, some it's not!
Definitely easier on the drive train though!!
#3427
I'm planning on going to 500k at the next rebuild to see how it feels. I'm a little cautious about packing the diff with putty rather then really think oil, but I'll give it a go one day
#3428
For me its simple, its easier to drive the a consistent, good line and a touch more forgiving. What I may be losing coming off the corner I have more than made up for in consistency. If you are an ace driver, it might not be for you. For almost anyone else, I just think it makes the car easier to drive.
#3429
Hi Guys
I was looking at some Carpet Setups and noticed Few Team Drivers are using 350CST SHOCK oil on carpet Tracks isnt that too Thin? I reckon Its equal to 25WT?
I was using Much more 350 (35WT)...
What WT shock oil You guys prefer on Carpet???
Cheers
Cheers
#3430
#3432
I got my t3'11 put together with all electronics yesterday and I must say that it was the best build i have had to date. I recently put a tc6 together for a friend and the xray kit was by far the better build of the two.
So, I couldn't resit running the car up on my bench. I knew the drive shafts would chatter at full lock, but man, it sounds like the car is going to tear itself apart. Is this normal?
#3433
Do you know if Yok and tamiya spring fit in Xray shock?
#3434
It's far less noticable when running on the track.
The only cure is ECS driveshafts which are a lot smoother.
Skiddins
#3435
If it really bugs you, pick up some ECS shafts for the front.
