mario rossi wht head ninja
does anybody has a piston/sleeve set up that comes with this engine or is there any rc store that has this across seas because i know theres no store here that has it somebody help me please
mario rossi ninja
yes mr21 tuned version with magnesium head
Both MR21 R01 are the same It is the same block all that changed is the Magneisum head and the bearings are ceramic that is all that changed ask anyone.
Novarossi won't fit, the crankpin is different (if I can remember right it is larger), maybe the rods of a RB will work. The piston pins are different so when building up you do need the rod beloning to the P/S set. I did fit a GRP set into a Novarossi engine and with using a NR rod I only needed to drill up the hole from the piston pin from 4mm up to 4.2mm
I know the early REDS racing models were based on GRP messurements or you have to look at the new Techonpower engines which actually are the GRP engines. Only no onroad P/S set but probbebly you only need to raise the exhaust port.
On the other hand, the time and costs is not worth it, getting a new engine seems to me like a better choice.
what are the benefits of the magnesium head?
+1 mugen and grp parts are getting harder to find I would go with a new block.
Only other option is to get it pinched.
I have the MR21 R01 engine block with no rear bearing and no piston. I also have an GRP .21 tuneline on-road with no front bearing and no piston and no conrod.
