GT8 Class--buggy-based on road electric!
#137
Originally Posted by bobbyblaze
thanks for the info..what about the aston martin body? __________________ Losi 8T 2.0\ Ninja .21 Ofna DM-1 Spec/GO 7 port M11/Spektrum Team Terribles
IMO, stay away from the Aston.. It was the worst handling body for gt. Zero down force in front... I lost count how many times the front nose came up on high speed runs and the car skid upside down half way down the street lol
#138
There are 2 Aston bodies. One that fits the igt and a longer one that fits the igt2.
#139
#141
have anybody try lipo's from Hobby King? __________________ Losi 8T 2.0\ Ninja .21 Ofna DM-1 Spec/GO 7 port M11/Spektrum Team Terribles
Also check out hobbypartz.com . They're based out of California and have similar prices to hobbyking, less the expensive shipping charges. The only problem is that their hard case car lipos sell out quickly.
#142
diff oil set up
Hello guys..
Any body running single speed?.. what diff set up you running?
Thanks,
Mike
Thanks,
Mike
#143
I've been looking around my LHS for 3cell LiPos, and the highest ones they have are 5500 25C. Is 25C going to cut it, or do I need to look for one with a higher C rating?
#144
Right now a lot of us are running single speed because we're on smaller 10th scale tracks. I'm just running a solid spool, a few other are running a center diff with Kyosho 500,000 wt oil, and another guy was using 100,000 wt oil. If you're running a center diff, I wouldn't run anything less than 100K.
#145
#148
[QUOTE=Matthew_Armeni;7632749]Right now a lot of us are running single speed because we're on smaller 10th scale tracks. I'm just running a solid spool, a few other are running a center diff with Kyosho 500,000 wt oil, and another guy was using 100,000 wt oil. If you're running a center diff, I wouldn't run anything less than 100K.[/QUOTE
Is there a solid spool for igt and where can i get it?
#150
[QUOTE=PinoyCali;7634668]
My car has a spool (Inferno GT). This is what I used:
http://www3.towerhobbies.com/cgi-bin...?&I=LXNWS7&P=7
It required a slight mod, the pin slot was not properly centered (a friend fixed with a mill. It fits in the center diff cup, replacing the gears. I can use any spur gear (including plastic, recomended) Kyosho makes.
So far it has been bomb proof with a big 2200KV Mamba Monster system in the car.
Here is a pic, not much to see though.
