RC10 GT Qs
Old 04-26-2004, 06:29 PM
Trader Rating: 36 (100%+)
Default RC10 GT Qs
I have an AE GT RTR...The problem Im having is the rear axle pins keep eating the wheels up. Im at a loss and any suggestions are appreicated
NitroOB4You is offline
Old 04-26-2004, 08:07 PM
Ybakoff's Avatar
You have to space the pin out from where the bearing is with some shims. You will find that the back of the rim is rubbing on the hub carrier and it chews up the back of the rim and the hub carrier.
Hope this helps. .
Ybakoff is offline
Old 04-26-2004, 08:56 PM
Aaron Waldron's Avatar
You can use the B4/T4 axles, which come with a washer that goes between the pin and bearing.
Aaron Waldron is offline
Old 04-27-2004, 03:01 PM
Duuhhhh me, lmao...I shoulda looked at it first...tis my friend's truck.....anyway..thanks for the input
Old 04-27-2004, 06:57 PM
Good luck!
Old 04-27-2004, 08:03 PM
skiptomylou6's Avatar
Hi i noticed that you have the RTR GT. Did you have problems with starting the engine for the break-in period?? I'm having quite a lot of trouble with starting it and keeping it running. I have like a quarter of a tank done. Any advice? Thanks i appreciate it.
skiptomylou6 is offline
Old 04-27-2004, 08:19 PM
If you've been trying to start it over and over, and have had the igniter on the glowplug for any good length of time, you probably have burned the glowplug out, and will need to replace it (a Dynamite/McCoy MC59 is a good choice).
Make sure the engine is primed (but not flooded) before trying to start it.
