Ofna Cd-3
#1306
The original clutch? Yikes. I hope you at least got the Mugen or Ofna 1.1 springs for it. You should be able to adjust it much better with that power clutch. Word to the wise, though: get that Ofna clutch tool. Trust me on this. I ended up replacing the adjuster nut and the clutch bell trying to adjust the clutch without it.
#1307
clutch nut size?
can one of you guys with a power clutch do me a favor?
on my pro, i have a GS Vision Pro power clutch. my question is, what is the nut size of the clutch nut from Ofna power clutch? for instance, the one i have now is 5/16.
#1308
Originally Posted by nitrothugg
.... on my pro, i have a GS Vision Pro power clutch. my question is, what is the nut size of the clutch nut from Ofna power clutch? for instance, the one i have now is 5/16.
The spring adjuster nut just has two slots for adjusting engagement.
#1309
does the one-piece engine mount sit the engine lower to the chassis then the other mounts?
#1310
#1311
The one piece engine mount is worth it, i like mine, although i did have to put different screws on the bottom hole's of the backplate to clear the one piece engine mount, could have also filed the the engine mount aswell tho, Curvetracer did you have this problem?
#1312
what engine you have?
#1313
#1314
#1315
Five minutes of work, and all engines fit with no interference.
#1316
Just for everyones info - STS Series engines (D5, D3R and D5R) fit the one-peice engine mount with no mods done.
#1317
Like Nightmare said, the RTR versions are slightly higher to clear the pull start. If you have a OS pullstart, you will still need a spacer of some sort to clear the pull start and the chasis. The RTR should also have a slightly larger flywheel to still allow bump starting. I know my LD3 had a larger flywheel and there was a smaller one for the SG shaft engine, which usually was a bump start. If memory serves, I still ended up using the original flywheel since I had the stock (higher) mounts and it would not touch the starter wheel.
Having the one piece mount does make it easier to get the gear mesh correct, but I'm not sure if it is a must have item unlike, say, the aluminum arm mounts or the CNC ring & pinion gear. If you have the pro mounts, they will do the job, but will take longer to get it right.
#1319
Yes, by accident. It's made from 3mm 7075 T-6 grade aluminum. There are a few more cutouts in the chassis, and the rear where the arm mounts and diff are come at an angle rather being straight. I had to adjust the rear starter box pegs a bit. Both the front and rear of the chassis are beveled, which makes the screws for the rear arm mount and the front bumper sit out slightly. Whether that will affect anything or not is unclear. Then again, if the car gets low enough to get to the screws anyway I have other problems to worry about.
I'll snap some pics of it this week and post them up.
#1320
*RELISTED* with some changes ofna ld3 rtr
