Tamiya TB-Evolution IV
#1411
Originally posted by Hebiki
I remember Rod and Fred talking at Mazda Cup.. it went like this...
Pant, pant, wag tail....woof!
#1412
Re: Re: Re: Re: Drive cups
Originally posted by EVOtech
You'll be lucky. I don't see thet happening. They would be admitting they have a problem.
53783 TB EVO 4 LIGHT WEIGHT ALUMINUM PROPELLER SHAFT 600YEN 30TH
53784 TB EVO 4 ALUMINUM REAR UPRIGHT 1.0 3600YEN 30TH
53785 TB EVO 4 ALUMINUM CENTER CUP 500YEN 30TH
53786 TB EVO 4 PNE-PIECE FRONT CENTER CUP JOINT 600YEN 30TH
Rick
#1413
So wherd'ya get the TRF shirts then??????
Tamiya Signature Line at Tamiya USA
Tamiya Signature Line at Speedtech RC
I hope this helps.
BTW, regarding the picture, we were actually talking about motors but the "check her out" part is right on the money...dayem!
#1414
oh what? oh ya.. evoIV thread.. my bad.... so um..rod are you switching to the evoIV permanently and ditching the 415?
#1415
As a driver for Tamiya, I suppose it would only be proper to represent As for picking up a shirt, they are available to anyone:
I hope this helps.
I hope this helps.
#1416
Thanks, found them, but I can't find a dealer that stocks them.
#1419
Originally posted by F. Alonso
Hey, does anyone know how much their car weighs fully equipped??? Especially those TCS legal cars!! I just wanna get an idea on how much ballast I need to get before my stuff arrives.
Indoor stock, fully up with a Sanyo 3000 and all the currently available lightweight bits, 1420g
Outdoor mod, with GP3300 and all the standard bits, save for my delrin drive cups for the prop, 1560g. I have built a spool out of Evo3 bits (reinforced outdrives and a plastic gear) for tommorow's racing, so it should weigh in about 30g lighter.
So, if you're outdoor, leave most/all of the original bits in. If indoor and not required to make the weight, use all the Ti bits and lightened propshaft bits etc.
#1420
We have two:
We have two:
Ali front/rear propshaft ends
Ali servo mounts
Lightweight ali driveshafts on the front
Evo3-ish standard diff on the front with lightweight outdrives
Silicon carbide balls in both diffs
Tam Ti screw kit (that saved a load)
Ti turnbuckles all round (inc steering arm)
Ti balls where possible
Probably gas balloons fitted where scrutineering can't be bothered to look
#1421
Okay, that gives me a good idea of what I need.
I have ordered:
Stabilizer Set
Tamiya Ti screw set
Tamiya Ti Turnbuckles 23mm
Tamiya Lightweight Universals
Tamiya Aluminium Ball Connectors
+ Having a Ball Diff up front with Lightweight Diff Balls throughout front and rear.
Aside from that, I've just bought spares.
My car will probably be around 1450 I think, maybe a lil less. I also have a Futaba S9550 servo and Novak GT7 in there, and a Tamiya Super Stock TZ or RZ will be in there too.
I've just ordered some great scales to weigh all of my cars to see what they are. Want them to be as light as possible!!! BUT LEGAL!!
I have ordered:
Stabilizer Set
Tamiya Ti screw set
#1422
Well ran the car for the first time on carpet in 19t. Used BSR 28mm foams. Orange/Purple Front and Purple Rear. Car was okay but could have had a much better setup. Rear end was loose. I didn't put much effort into trying to setup the car because we only raced carpet since it rained today. So back to asphalt next time. I will say I'd like to try my 415 on carpet next time out though. I feel it will be much smoother than the Evo IV was. But we'll see. Anyway's the Pro4 front spindles held up and had excellent clearance for the 28mm foams. I just wish they had a thicker chassis for the car.... Oh and the GTX esc worked great. First time out with that...
#1423
Which is better, the TB Evo 4 or the TRF 415?
#1424
Team EAM
Kilruf...You think the car will be good with a thicker chassis on carpet? I still have mine....Havent sent it back to dave yet (sorry dave!!). Thought about trying it on carpet before I sent it off. Our track opens up next weekend. 72x48. Should be fun!!
Wouldnt mind finding a 415 with a front diff to try either!!
EA
EA
#1425
EA, I thought the car was yours?? Just a loaner from Dave? Ain't that the shnitz... Anyway,s I didn't really have time on the car to set it up. We were suppose to race asphalt that day. But since it rained, we just prepped up the carpet track and ran it instead. So first round I just tossed on a set of foams (60mm) with no change in setup except ride height. Then 2nd round I tossed on a set of AE White/Purple springs. I think 3rd round I took off the 2° caster blocks that I run on asphalt and stuck on the 4° blocks. For the main I just added 1mm more shims under the rear camber link. So I was slowly working on the setup throughout the day. But not really enough time to set it up right. The rearend liked to hang out/drift. So I had to fight that the whole time. Tons of steering goin in. And noticable torque steer with the 19t. I'd very much prefer the 415 on carpet if I can build a diff for it. I'd just like the Evo IV to be a bit smoother through the turn. I also had -60% steering EXP to start with. I should set it back to 0 and start there. Anyways... more than likely I won't be til November before I get to run on carpet again... unless if it rains... By then I should have built a diff for the 415.
