Final Drive Ratio for an Xray t2008
Hey, going to need a LOT more info than that man. Track size, esc, esc timing profiles, track layout (flowing or technical) etc. I run a tekin RS, timing of 50 /10, 0 on motor timing, 100 x 60 track, pretty flowing, and I ran between 5.8 and 6.4 depending on the heat and timing settings. If you have a sphere tc or something with less dynamic timing you will be running closer to the 4.0 range. But if you can afford it the tekins are pretty amazing if you don't already have one.
