Is the MBX5T still good compition for the newer truggies???
on a tight indoor track stiffen the rear sway and remove the front sway...add more rear toe in , and use slightly more front to out
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Maximo... ADD toe in? (rear) That locks the rear down more... are you sure? I'd reduce toe to let it rotate... depending on how the truck behaves of course.
I am sure ( or at least I am sure I am sure LOL ) ...when you add rear toe in you create scrub, which means the rear tires have already broken traction so its easier for the rear to rotate...on my high powered engines I have to reduce rear toe to keep the back end from spinning out.....
