have any 4 stroke engine for car?
i want to buy a glow car, what are the different of the 2 stroke and 4 stroke engine?
4 strokes
i m getting ready to do a 4 stroke project .
check this out
http://www.rcuniverse.com/forum/m_82...52/key_/tm.htm
maybe that will get you pumped up about the 4 strokes
check this out
4 stroke engines GENERALLY are not used on smaller RC cars, ie 1/10, 1/8.
The reason is because they are heavy when compared to a 2 stroke that produces the same torque at a given RPM. 4 strokes don't produce their torque at as high of an RPM that the 2 strokes can. A 2 stroke engine when compared to a 4 stroke of the same displacement can produce WAY more RPM. Weight is everything in these cars. You are fighting un uphill losing battle against the laws of physics if you think your going to find a 4 stroke that will compete against a high end .12 .21 or .28 two stroke RC engine...
Four strokes are generally only use in larger 1/5 scale or 1/4 scale cars...
Now that being said. If you were to come up with a forced induction 4 stroke RC engine then you might be able to get your power/weight up closer to that of a comparable 2 stroke rc car. Keep in mind you would need to gear the heck out of it. Since the 4 stroke would be producing all its power down low on the RPM range and its max RPM still would not compare to a 2 stroke.
4 stroke engine applied in RC car, it is more stable.
There is are 4 style mini design and high performance engine from Toyan.
You can get all the nice engine from enginediy
