Durango DEX210 Thread
#5763
http://www.amainhobbies.com/advanced...0+spur&x=0&y=0
Speedtech carries the schumacher cat and cougar spurs but they are sadly out of stock.
#5764
yep 83 is a good mid range spur, the smallest pinion u can go with with a 83 tooth spur is (99-83) around 16 so FDR range is 13.5 ~ as low as you dare . I myself have the 69, 76, 78 and today got the 83 RW spur. Testing and racing saturday with the 83 (with new 10.5 MMM motor).
So a 22t pinion will work well with the 83 spur?
How about springs? I want to buy a couple of pairs fr/rr to carry around for fine tuning instead of buying the whole spring set.
#5766
Add 1 more to the durango fam. I just got a 210 even though i was told not to. (But i have faith in it) just wanna c if i can get a base setup for med. Traction, clay setup to start off with. Just like all of us im very competitive and i want to prove the hatters wrong. Which ive already some with my blitz...
#5767
https://docs.google.com/viewer?url=h...BoreSpring.pdf
If you need to in a pinch, the losi springs work well with the rangos. I have a bunch bought from my lhs. Used front/rear oranges now from losi. The weights are in the above charts. I always carry a printout to the track. Try Raul's setup for RM4 with losi springs if you guys want.
http://www.petitrc.com/setup/durango...ngoDEX210.html
#5768
The kit specific either has the balls and stuff for $80 and the ones I just saw come in pairs for $24 for only 2, I saw the b4 punisher for $26 for all 6 so I was just curious if anyone has tried it. Looks like I am, if I have to trim it down a 1/4" no biggie.
#5769
Yep should be plenty with a 7.5. Used to run a tekin 7.5 long back. Springs if you badly need are dark blue rears. The stock fronts are fine, in fact they are a bit harder for my tastes so I went light green in front. Try this chart out
Awesome, thanks for the chart!!
How about closed cell foams, which is the most consistent: AKA, PL, or JC?
#5770
When running cc foams we use the AKA in JC and Panther tires, but prefer the Pro Line cc foams in Pro Line tires- they just seem to fit better. Also like to use Trinity Bomb One foams quite often. Almost always use a cut down rear open cell foam for front tires on our cars.
#5773
Just picked up a set of front Barcodes gold with Proline CC inserts for indoor clay.
What are you guys doing for venting? Holes on the tires? wheel? how many holes, etc....
#5774
+1 on the new JConcepts Rear Foams. Once broken in, so nice and consistent. For Fronts I still preffer Pro-Line CC. For Tires Jconcepts V1 Bar Codes rear, and Bar Codes front seem the ticket at the tracks I race on (medium to high bite indoor clay). Your milage may vary.
#5775
