Durango DEX210 Thread >
Like Tree80Likes
Old 09-24-2014, 07:01 PM
  #15121
Redsawacs's Avatar
Trader Rating: 38 (98%+)
what gear should I be running in 17.5...69 spur?
what spring set for the front? Hard or regular?
Redsawacs is offline
Old 09-24-2014, 10:01 PM
  #15122
EbbTide's Avatar
Trader Rating: 39 (100%+)
Originally Posted by 13Maschine
do you have a part number by chance? I actually have an 81 for my DEX210 but I really need one for my DEX410…not sure if the shumacher would fit that car too?
I don't know about the 410 working with 4wd Schumacher spurs, but below you will find a link to one of the Schumacher spurs that works for the DEX210. Their sizes range from 83t-71t from what I see on Amain.
http://www.amain.com/Schumacher-Raci...ar-83T/p170698
EbbTide is offline
Old 09-24-2014, 10:25 PM
  #15123
EbbTide's Avatar
Well in 17.5, go with as small a spur and as large a pinion as you can fit with the motor and ESC temps staying in the safe range. Every bit of extra power counts in 17.5 so it will probably take you a few packs at your local track to figure out the limits of your motor and how .
I'd just start wth a 71t Schumacher spur or an RPM spur with an Exotek slipper eliminator and get a nice set of aluminum pinions from 30-38t then spend a few packs rounding your local track, changing gears and checking temps. :-)
EbbTide is offline
Old 09-25-2014, 09:21 AM
  #15124
13Maschine's Avatar
Thanks Ebbtide!
13Maschine is offline
Old 09-25-2014, 10:19 AM
  #15125
13Maschine's Avatar
Regular spring set
Old 09-25-2014, 10:35 AM
  #15126
Redsawacs's Avatar
copy that....60$ is springs....sigh
Old 09-25-2014, 12:03 PM
  #15127
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
lol. man some of these spur gear prices are up there. wonder if there is gold hidden in em
Cain is offline
Old 09-25-2014, 12:29 PM
  #15128
13Maschine's Avatar
If you wanted to buy individuals you'll probably want to go with a set of springs that are one increment stiffer and one increment softer on each side to start with. Along with moving the shock positions around that should give you a good range of adjustment to start with.
Old 09-25-2014, 10:18 PM
  #15129
Redsawacs's Avatar
I suppose I'll be putting another order in after the car arrives! LOL
Thanks for the tips all...More to follow, I'm sure.
Old 09-26-2014, 11:01 AM
  #15130
Devin's Avatar
I am putting together a ball diff for my DEST. the diff feels like it is rubbing against the gearbox. When I install the spur gear, I can feel certain spots where it is free and where there is excess binding. Anyone have an idea of what may be going on?
The gearboxes my DEX and DESCl go together no problem, but I bought them used. Wondering if there could be user error I am doing.
Devin is offline
Old 09-26-2014, 11:17 AM
  #15131
Dino_D's Avatar
You don't really need the whole set.
Kit comes with:
V1 (Light Blue Front / Light Blue Rear)
V2 (Black front / Light Blue Rear)
excluding the springs that come with your kit....
TD Progressive Springs that you should get:
Front: Light Blue, Black, Light Red, Dark Green
Rear: Black, Dark Green
You will never use springs lighter than light blue. Unless you race on hardwood or in a gym floor.
Another thing you might want to consider is a Linear Set:
TLR Low frequency TLR22 front and rear springs set.
Dino_D is offline
Old 09-26-2014, 11:26 AM
  #15132
EbbTide's Avatar
Some of the older gearboxes were defective and would cause similar binding after some use. I had an issue like that with my DEX210 when I replaced a broken gearbox.
The new one caused the gears to bind when I attached the motor plate to the gearbox. The only way to prevent the binding on my old gearbox was to use red thread-lock and just leave the screws for the motor plate almost finger-tight instead of cranking it down with the hex drivers. That got rid of the majority of binding for me.
But what got rid of ALL of the binding for me was switching over to the type-b gearbox and chassis for the DEX210. Now I can crank all of the screws down and not worry about binding.
EbbTide is offline
Old 09-26-2014, 11:34 AM
  #15133
13Maschine's Avatar
I've also experienced these types of issues with my gearbox. Sometimes the binding is caused by using the wrong size spacer in between the motor plate and gearbox. This makes the plate tilt a bit. This is one of the reasons I like the tresrey motor plate it comes with a spacer that screws into it so you can't lose it.
Old 09-26-2014, 12:40 PM
  #15134
Devin's Avatar
This is building a brand new kit, there should be no wear. Even without the screws, just by completing the two halves there is binding. This is before a motor plate or anything comes into play.
My kit has a number of type b items, the chassis for sure. Could I be dealing with a type a gearbox?
Devin is offline
Old 09-26-2014, 01:00 PM
  #15135
EbbTide's Avatar
It is possible that you are dealing with an original gearbox instead of the type b gearbox. If you want to clarify that, you should be able to tell the difference if you compare your gearbox to that of a type b gearbox. Images of those should be available on Amain's website or VIA Google for reference.
I've had brand new gearboxes create binding in the drivetrain before, so it doesn't need to be worn to cause binding. The issue is with the plastic and the mold they used for the old gearboxes. They had a tendency to warp easily which caused the binding.
If you can confirm that you do have a Type B gearbox and still experience binding, then I'd start to check all of the gears to see if there are any chips or deformities in the teeth of the idler, and diff gear
EbbTide is offline
